Auto transmission question
Old Apr 14, 2012 | 01:04 PM
Thegreencantina's Avatar
Thegreencantina
Hi all. I'm new to the diesel super duty scene. Just bought a used 2003 F-350 and had a question. When I drive in"tow" mode I can hear the rpm drop from the torque converter. However, when tow mode is off and I'm in fourth (overdrive) I dont hear the rpms drop. Is this normal? Seems like other vehicles rpms drop at highway cruising speed. Is this normal? Thanks!
Old Apr 14, 2012 | 01:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I assume that you have a 7.3L diesel, right? If so, there is no "tow" mode on that truck. There is a button on the end of the shifter that turns off the overdrive.
When you are in fourth gear (overdrive) the torque converter will lock up if you are over about 40 MPH. It usually will lock during the 3-4 shift, so you won't notice a separate RPM drop for the lockup.
You can check it at 45-50 MPH. Hold the go pedal so that you are at a constant speed for at least 10 seconds. Without moving the go pedal, use your left foot to gently press the brake pedal. When the brake pedal is pushed the torque converter will unlock and engine RPM should rise by about 200 RPM.
Old Apr 14, 2012 | 01:24 PM
Thegreencantina
Awesome. Thanks for the quick reply. I'll check it today! Cheers!
dpslusser
16
Sep 12, 2012 05:42 AM
bren7176
Apr 2, 2011 10:32 PM
KoolAidMan888
Nov 28, 2010 09:08 PM
jdreb13
Jan 25, 2007 02:19 PM
rick.wooldridge
Jan 12, 2005 04:11 PM
