Tranny question
Old Apr 2, 2011 | 09:38 PM
bren7176's Avatar
bren7176
Tranny question
so I notice a few days ago when driving if i let of the accelerator pedal the rps will climb a bit at a coast like the tranny is gearing down . Now if you tapp the brake pedal the rpms drop and it sounds like the trans is disengaged ?
So am i paranoid or is there something wrong there??? or is this normal..might havebeen doing it all the time but i just noticed it ...
Thanks
Brendan
Old Apr 2, 2011 | 09:42 PM
woodnthings's Avatar
woodnthings
Sounds like the torque converter unlocking when you tap the brake. What speeds are you noticing this at?
Old Apr 2, 2011 | 09:59 PM
bren7176's Avatar
bren7176
i notice it in overdrive . speeds at 50-and up, you think the converter lock up is failing or something else causing it . or is this normal???
Old Apr 2, 2011 | 10:07 PM
woodnthings
Not sure about the rpm's climbing when you let off, but tapping the brakes can disengage the TC when cruising.
Old Apr 2, 2011 | 10:32 PM
bren7176's Avatar
bren7176
okay that might be it , for some reason i never noticed it
