gearing??????????????
Old Apr 14, 2012 | 07:21 AM
cws10190's Avatar
cws10190
my buddy and i was talking last night, and we came to the conclusion that 450hp is a bit to much for the gearing in my truck. i have some chevy 5.13's. we r under the impression tht it will run out of gears way to fast, i wanted to run some 4.10 but he still thinks ill be redline before quarter mile is up, so what do u guys think. truck isnt going to be track truck, but will b at the track occasionally. basically will b play on interstate with my buddies import cars on the way to r fishing holes and also to mess around town with. it has a 4speed shtick in it idk the gear ratio's. but would still liike to c 100mph+ bc its always fun to see peoples faces after they get smoked by a 45 year old truck. i will be running 33's and 31's i got 4 31 drag slicks and 1 set of road tires and a set of 33 boggers. mostly run the slicks around town whiich r the 31's
Old Apr 15, 2012 | 10:53 AM
critterf1's Avatar
critterf1
Trying to make some sense out of this very long "sentence/text". What kind of truck? Engine size? Chevy 5.13's?
Old Apr 15, 2012 | 11:06 AM
cws10190's Avatar
cws10190
74 f250, 390, chevy 5.13 gears super low pulling gears
Old Apr 15, 2012 | 11:30 AM
73 ford guy's Avatar
73 ford guy
4:56 might be an ideal ratio. What axles are you running? What makes it a chevy 5:13? If it's a Dana axle they are just gears as they came in chev,dodge,and ford. If you run a chevy 14 bolt rear I could see you call it a chevy gear.
You should of posted this in the Offroad forum or even 73-79 section. You'll get more responses. I Only seen it as I got a notification you made a new post after adding as buddy.
Old Apr 15, 2012 | 12:07 PM
cws10190's Avatar
cws10190
ok thanks for the advice always thought 5.13 was chevys. i like those gears they will pull a house over but u cant keep the rear end down wen i run my buddies and no top end
Old Apr 15, 2012 | 12:21 PM
73 ford guy
I run 5:13's but with 44''swampers. Seems to work fine with lots of gear. I may have gone 5:38 but the don't make that gear for a d70 rear like I have. 14 bolts and d60's did but no 70.
Old Apr 15, 2012 | 12:23 PM
73 ford guy
Again what axles do you run and want 450 hp with?
Old Apr 15, 2012 | 01:05 PM
cws10190's Avatar
cws10190
dANA 44 front and 60 rear, when im done on the build it is a safe guess on 450 hp, i want to run dana 60 front and rear on 33s, you run 5.13 but you have 44's wich gives you the extra gear you need. plus 44s take a **** ton of power to run good too. i love seeing 200hp toyota with 44s. its funny that they think the axles and motor is beefy enough.
Old Apr 15, 2012 | 01:12 PM
73 ford guy
Throw the d60 rear in the trash. Go 14 bolt, sterling 10.25 or d70
Old Apr 16, 2012 | 09:22 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I run a Dana 60, in a 70 F250 with a semi mild 390 and a C6 with a a set of 4:10's in the back with 33x12.50x16.5's on it..and its the best of both worlds..I wouldnt even consider running 5:13's in the back unless I was Truck pulling..and its still has enough Torque to blow the tires off from a stop with a Soft locker in it..from a dead stop ! I think with my BFG T/A radials..it runs about 2500rpm at 60+ mph.. I can pull a trailer with it..and not even know its back there..and yet still make the Dodge boys cry for mercy !! JMO...
Keep us posted !
Ron94150
6.2L V8
Apr 14, 2017 10:34 AM
BuiltToughF250
Jun 5, 2007 09:52 PM
F250DOOOK
Offroad & 4x4
17
Dec 11, 2005 10:36 PM
78 Ranger
Jul 27, 2005 04:05 PM
venom69
Jun 2, 2003 08:32 PM
