Offroad & 4x4
gears for 44's?
Old Dec 10, 2005 | 08:47 PM
F250DOOOK's Avatar
F250DOOOK
gears for 44's?
as you all probably know by now, i recently bought an 85 f250, and i'm going to put 44's on it. i was wondering what gears i will need? it has a 302 in it, so ther's not much power, i'm going to do alot of bolt on's, cams/carb/headers/ingition/etc... the track i'll be running at can't be but maybe 1/8 mile. it will not be driven more then a couple miles at a time on the street, so i'm not concerned with streetability, just getting down the track fast as possible.thanks!!!!
Old Dec 10, 2005 | 09:00 PM
MBBFord's Avatar
MBBFord
I'd use at least 5.13 gears, and I would think about putting a built 460 also.
Old Dec 10, 2005 | 09:06 PM
monsterbaby's Avatar
monsterbaby
going with 5.13 would be equivilant gearing to running 3.73 with 32" tires, and 5.38 gears would be equivilant to running 3.91 with 32" tires niether of which is a real low gear I wouldn't go any higher gears than the 5.38, and more like 5.50s or something close if you can get them for the axles you have (no you can't get them for a D44HD)
Old Dec 10, 2005 | 09:29 PM
F250DOOOK's Avatar
F250DOOOK
the lowest i can find is 5.38's, i have the ifs front, is that a d44?
Old Dec 10, 2005 | 09:31 PM
F250DOOOK's Avatar
F250DOOOK
i am in the market for a 460. that's my goal!!
Old Dec 10, 2005 | 09:40 PM
ivanribic's Avatar
ivanribic
You're trying to race with 44's on an IFS D44 front with a 302???
Old Dec 10, 2005 | 09:47 PM
F250DOOOK's Avatar
F250DOOOK
i'm leaning towards findong a d60 front, where is a good place, and how much do they run? i have two d44, or d50's whatever they are. is there any place to sell them?
Old Dec 10, 2005 | 10:00 PM
ivanribic's Avatar
ivanribic
Check ebay and your local junk yard. They'll run $1000-$1500 for a used axle. If you want a new one try Dynatrac. They'll charge about $6K for one of theirs.
Old Dec 11, 2005 | 08:37 AM
bremen242's Avatar
bremen242
for that kinda of dough, don't even stop at 1 ton axles. go straight to 2-1/2 ton toploading rockwells.
Old Dec 11, 2005 | 08:44 AM
Thomasm67's Avatar
Thomasm67
Can't get what Rob for D44HD?
Old Dec 11, 2005 | 02:16 PM
monsterbaby
Any gears lower than 5.38.
Old Dec 11, 2005 | 06:46 PM
chrono4's Avatar
chrono4
wow, now that would be a disaster. 44's on dana 44 and a 302. you might be able to get it to move.
Old Dec 11, 2005 | 07:13 PM
RawPower's Avatar
RawPower
Ive seen worse... in petersen's, go figure...
Old Dec 11, 2005 | 07:33 PM
Stroker_Deezel's Avatar
Stroker_Deezel
He has an IFS 250, it should be a D-50. Not that its any better though.... Dook, where are you located?
Old Dec 11, 2005 | 08:07 PM
monsterbaby
actually worse less choices on gears
