2003 6.0 branch tubes
Old Apr 13, 2012 | 09:58 PM
princetondiesel's Avatar
princetondiesel
any tips on removing the branch tube from the heads without removing them. covers off, trans pulled. tks
Old Apr 13, 2012 | 10:07 PM
BLADE35's Avatar
BLADE35
you need the special tool
are you pullen the Heads???????
<TABLE border=0 cellSpacing=0 cellPadding=0 width=773 align=center height=1121 cool gridx="10" showgridx usegridx gridy="10" showgridy usegridy><TBODY><TR height=40><TD height=40 width=772 colSpan=4></TD><TD height=40 width=1><SPACER type="block" width="1" height="40"></TD></TR><TR height=1050><TD height=1080 rowSpan=2 width=10></TD><TD height=1050 vAlign=top width=762 colSpan=3 align=left xpos="10"></TD><TD height=1050 width=1><SPACER type="block" width="1" height="1050"></TD></TR><TR height=30><TD height=30 vAlign=top width=110 content csheight="30" xpos="10">Page_068.html</TD><TD height=30 width=550></TD><TD height=30 vAlign=top width=102 content csheight="30" xpos="670"></TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1 cntrlrow><TD height=1 width=10><SPACER type="block" width="10" height="1"></TD><TD height=1 width=110><SPACER type="block" width="110" height="1"></TD><TD height=1 width=550><SPACER type="block" width="550" height="1"></TD><TD height=1 width=102><SPACER type="block" width="102" height="1"></TD><TD height=1 width=1></TD></TR></TBODY></TABLE>
Old Apr 13, 2012 | 10:17 PM
princetondiesel
trying not to remove heads. everything is disconnected, pushrods blocking egress.
Old Apr 13, 2012 | 10:22 PM
BLADE35's Avatar
BLADE35
so are the branch tubes leaking or something????????
they seem to be problem free for most part on an 03 but anything possible
djanzen's Avatar
djanzen
Use a die grinder wrench. Works for me every time
Old Apr 13, 2012 | 10:29 PM
princetondiesel
explain???
Old Apr 13, 2012 | 10:33 PM
princetondiesel
i guess what I am saying is do you have to remove the back top 2 head bolts to get the tube out.
Old Apr 14, 2012 | 05:39 AM
texans's Avatar
texans
No you don't need to remove the head or any head bolts. Assuming you are talking about the standpipes. They just take a thin wall 18MM (IIRC) socket, and the tool, or diagrinder wrench, to remove the braided line that goes to the oil rail.
Old Apr 14, 2012 | 07:55 AM
princetondiesel
I am talking about the branch tube below the hpop that the standpipes thread into. Is it possible to remove the pushrod tubes without removing the 2 headbolts? The branch tube is held in place with 2 8mm bolts. It has to be pulled out the back.
Old Apr 14, 2012 | 08:21 AM
texans's Avatar
texans
That's what I figured you were talking about. I can't see anyway you could get to the bolts to undo the branch tubes without removing the heads first.
Yes it has to come out the back.
6.0's rock
May 2, 2016 02:24 PM
6.0's rock
May 2, 2016 01:34 PM
MisterCMK
Oct 23, 2015 01:58 PM
Shaneb75
Jan 2, 2015 11:20 AM
miteldan
Nov 25, 2012 05:10 PM
