Hubs?
Old Apr 12, 2012 | 04:39 PM
Dyllan78's Avatar
Dyllan78
Hubs?
My hubs wont turn very easily by hand, one of them has a small hole in it. Is there any aftermarket ones that i can use that will work better or should i stick to the stock and turn with chanel locks if i have too? If the one that has a small hole gets worse, again, do i go aftermarket or oem?
Old Apr 12, 2012 | 06:28 PM
wulfman's Avatar
wulfman
If they won't turn by hand then they need to be taken off and cleaned and greased.
Old Apr 12, 2012 | 10:51 PM
Dyllan78's Avatar
Dyllan78
Is there aftermarket hubs that are metal instead of plastic
Old Apr 13, 2012 | 10:39 AM
sullyt28's Avatar
sullyt28
I thought you needed to lock the front hubs for the front assist to work. I used channel locks for 3 months before someone informed me.
Is there a benefit to locking the front hubs ?
Old Apr 13, 2012 | 12:22 PM
wulfman's Avatar
wulfman
Yep when you turn that dial you know you have 4x4 .
Old Apr 13, 2012 | 09:02 PM
GreenPSD's Avatar
GreenPSD
Depends on the year of your truck. There are for the 99-04 trucks. Most go with Warn or MileMarker. There are no aftermarket hubs for the 05 and up trucks. Ford changed the design that year.
Old Apr 14, 2012 | 09:49 AM
Dyllan78's Avatar
Dyllan78
thanks ill check those out
2002exPSD
Aug 26, 2016 06:42 AM
bkeese
Oct 23, 2014 01:47 AM
mike L
13
Feb 26, 2008 09:36 PM
mstennes
Dec 15, 2004 11:05 PM
butchf250
Jan 13, 2003 12:11 PM
