Dash gauges pegging?
Old Apr 13, 2012 | 06:13 AM
iwlbcnu's Avatar
iwlbcnu
working on a 1979 F600 i just got and the temp and oil gauges are pegging and the fuel gauge goes to 1/4, but only when running not just with the key? I replaced the cluster reg and still same result. I thought when it goes bad they would peg just w/ the key? Anyway the gauges were working for the first month. I know the float in the tank is shot, but the tank shouldn't read at all. I was getting them to work by fooling with the reg at first, but it was intermittant.
Old Apr 13, 2012 | 06:19 AM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
Check the ground(s)
Old Apr 13, 2012 | 06:59 AM
OldStyle's Avatar
OldStyle
Rusty Roller
I would pull the wires off the sending units, oil & temp, on the engine and see if the gauges do the same thing. If they do then the wires are grounded somewhere along the line.
For the gas gauge you can ground the sending wire at the tank/sender and the gauge should top out.
Old Apr 13, 2012 | 08:38 AM
iwlbcnu's Avatar
iwlbcnu
Gauges were working, if grounded they should peg with just the key on.
fuel gauge works by ground, but KNOW the float is gone, so should only read empty, but goes to 1/4 when messing up, when the gauges work it reads empty.
Gf2501
Jun 27, 2014 09:40 PM
mrnapolean1
15
Aug 8, 2013 10:44 PM
Oleblue74
Aug 13, 2005 11:54 PM
usherac21
Dec 3, 2004 08:24 AM
pctjk
Electrical Systems/Wiring
May 9, 2004 01:28 PM
