Inop Gauges
Old Dec 2, 2004 | 09:52 PM
usherac21's Avatar
usherac21
Inop Gauges
I have an 89 F150. The oil pressure gauge, fuel gauge and temperature gauge are not operating. The speedo, tach and voltmeter are working. Is there a problem that could be causing the three gauges to be inop or does it indicate three separate problems? Any help would be appreciated.
Old Dec 3, 2004 | 07:31 AM
Buster89's Avatar
Buster89
I hope someone else replies to this. My 89 has a rear gas tank gauge and voltmeter that doesn't work. I think the other gauges are working. HMMMMMMM.
Old Dec 3, 2004 | 07:35 AM
RR4E's Avatar
RR4E
Could be one of a few things. Sending unit per gauge(depending on gauge, some have sending units, some don't_ could be the voltage regulator/rectifier on the back of the dash panel causing this(Ford's not so great idea) and could just be dirty connections, weak wires(corrosion at terminals or in the wire itself). Removing each connection, cleaning them, best start, most time consuming, but no parts required. Check for broken wires, bad grounds, etc. Replace the sending units, replace the voltage reg/rect on the back of the dash panel. If none of this fixes the prob, the guages are screwed...but I'd bank on the gauges as a last resort.
Old Dec 3, 2004 | 07:38 AM
usherac21's Avatar
usherac21
Thanks, RR4E, I'll give it a shot this weekend and let you know how I make out.
Old Dec 3, 2004 | 08:24 AM
Saurian's Avatar
Saurian
Only one of those you'll miss is the fuel guage - the other two never did a THING for you anyways.
