DO you also have any test procedures or test values for this sensor. I have the ability to bench test this device but not sure what my values should be.
Thanks, Kevin
I think it's supposed to be close to 5 volts in place, engine off (like about 4.5) but I am unsure - I looked through all my data and I never measured the volts. I think this is a capacitive sensor, which would rule out reading ohms.
Now I'm going to publicly argue with myself - just to show I'm not choosy who I pick on. I have the official document for the voltage readings on the EBP sensor output (middle wire).
0 = 0 PSI (or perfect vacuum) if you see this, it's a bad sensor or you are standing in the wrong place at the wrong time. 1.25 volts for every atmosphere/Bar/100 kPa (about 15 PSI) up to 5 volts, or 60 PSI max. 1.25 Volts is what you should see engine off.
Wow, again this site did not let me down! I will trouble shoot my sensor and report what was found......
Thanks to all who weigh in....
Kevin
SO far it looks as though the tube from the manifold up to the sensor was more than half way up the tube plugged with soot and it appears that that sensor is stuck on one value. Looks like a new sensor is in the near future....
