bad tie rod?
I don't see how the popping could be causing activation of the ABS unless the popping is actually in the wheel bearing/hub. If that's the case, you should have some serious safety concerns if the bearing is that loose.
-Rod
By | 2026-06-03 09:51:16
By | 2026-06-03 10:59:05
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
By | 2026-05-18 19:34:33
By | 2026-05-18 19:26:42
By | 2026-05-18 19:20:37
By | 2026-05-12 18:07:46
By | 2026-05-12 13:09:47
