Sponsored by: Auxito
tie rod ends
Old Mar 4, 2013 | 12:15 PM
mikren's Avatar
mikren
tie rod ends
hey guys, I did a brake job on the old girl today and happen to notice there's some play in the tie rod ( at the rubber bushing ends ) is that normal ?
Mike
Old Mar 4, 2013 | 01:53 PM
bashby's Avatar
bashby
They will rotate, it's a ball and socket joint. To check them rock the wheel side to side while jackd up. You'll feel a clunking if they are bad. Verify visually where the play is... inner/outer tie rod, wheel bearing...
Old Mar 4, 2013 | 03:10 PM
Spotty's Avatar
Spotty
It should be tight....if it moves then alignment changes.
Old Mar 5, 2013 | 08:57 AM
mikren's Avatar
mikren
ok thanks.....they do both rotate. (hence the ball and socket joint i guess ) i did notice moving the wheel side to side there is some play in the tie rod that way as well.....replace ???
Old Mar 5, 2013 | 02:07 PM
MIKE 04 GT's Avatar
MIKE 04 GT
if the tire move in from the 9-3 oclock positions Wheel bearing, or tirerod ends. if it move in the 12-6 oclock Positions that will be upper and lower ball joints
Old Mar 5, 2013 | 02:16 PM
mikren's Avatar
mikren
ok thanks. I can visually see the tie rod move back and forth when i move the tire side to side.
Old Mar 5, 2013 | 02:21 PM
MIKE 04 GT's Avatar
MIKE 04 GT
also look at the idiler arm , and pitman arm to see if there is any play there. how many miles? and is it a street queen or do you have it on alot ofrough roads?
Old Mar 5, 2013 | 06:40 PM
mikren's Avatar
mikren
let's say it's more street queen. It's a 99 with a 193000K
Old Mar 6, 2013 | 07:16 AM
MIKE 04 GT's Avatar
MIKE 04 GT
probley time for ball joints, tie rods, pitman arm, and a new idler arm as well with those miles. I just did all this to my f150 Mine is 4x4 for about 250.00 after the alingment. I got everything in a kit on ebay for like 180.00 then 35.00 for idler arm, then the alingment. Some says only go with moog, But i have hurd moog was not all that good anymore, I dont know how long the ebay ones will last but i am sure they will last as long as autozone one will.
Old Mar 6, 2013 | 08:28 PM
mikren's Avatar
mikren
checked the ball joints and they're good. they were done a couple years ago. looks like just tie rods need to be done. I'm finally selling it this summer and bying new 2013 or 2014 in fall.
Old Mar 6, 2013 | 08:39 PM
Spotty's Avatar
Spotty
What......? It's worn to perfection at this point. You're gonna' be sad.....
Old Mar 7, 2013 | 05:59 PM
mikren's Avatar
mikren
lol, true dat. I will be sad to sell it. I've had her since she was a year old and it has been nothing but good to me. The body is still rock solid and no rust.... The new owner will be getting a hell of a good truck. I'm due for new man, i've had this baby for 13 years.
Old Mar 7, 2013 | 06:27 PM
Spotty's Avatar
Spotty
Yeah...I hear ya'. Mine has 240,000 miles on it and I still use as my DD in my construction business. But rust is just taking over underneath.....I can't stop it. I spent 10 hours on Saturday doing the passenger side exhaust manifold....what an absolute PITA to do. I'm going to be forced to get a newer one myself.
Old Mar 8, 2013 | 02:40 PM
fordcrzymike's Avatar
fordcrzymike
Go with Moog, they cost more than the house brands (autozone, o'reily's, etc.) but they are WAY better. I used the house brands at first then started using Moog. I will never go back. Ask to compare the 2 side by side and you can just see and feel the quality with the Moogs. Although if your selling it soon you might as well save yourself some money and buy the cheap stuff.
Old Mar 10, 2013 | 06:56 PM
mikren's Avatar
mikren
yeah spotty...that's the thing. It's becoming not stop one thing after the other, so I'm just keeping it in half *** shape for when I sell it. ( cheapper parts )
I even looking at....( cover your ears ) the 2014 GMC Sierra all terrain.
