Lost the cam sensor while driving
Old Apr 11, 2012 | 09:46 AM
run6.0run's Avatar
run6.0run
I've never had it happen before, but I was loaded in canada, then the truck started losing all ignition (basically acting like I was turning off the ignition, then turning back on). I then got off the road then let it idle while going through my checklist. Then it died. I tried to start it once, then took a nap. When I got up, I replaced the cam sensor (letting it die caused the code to trip, and I ride with an extra cam and crank sensor). Just thought I would share this. Btw, she fired right up after the swap.
Old Apr 11, 2012 | 09:56 AM
Kert0307's Avatar
Kert0307
Mine threw a code for the cam sensor last winter, but was still running fine, I cleared the code and it's been fine since... maybe I should be riding with a spare from now on. Thanks for the post.
Old Apr 11, 2012 | 11:11 AM
Crash16's Avatar
Crash16
I want to add that if a plug on the ficm loosens up just a bit, it can do the same thing. Personal experience...
Sspurlock
Oct 8, 2016 01:47 PM
Roasted7
Feb 3, 2013 08:07 PM
semperfipsd
Aug 24, 2004 08:18 PM
ltlrace
1983 - 2012 Ranger & B-Series
Dec 16, 2003 06:31 PM
kentpsmith
Modular V8 (4.6L, 5.4L)
Jul 7, 2003 09:08 AM
