tc - flexplate question
Old Apr 10, 2012 | 06:46 PM
heathrunkles's Avatar
heathrunkles
I swapped motor in my truck--dropped a 01 in the truck. It was a manual truck and mine is automatic. I removed the 1\4 spacer behind the bellhousing adaptor and used the crank spacer and flexplate from my auto. I bolted the trans and the motor together(studs were alighned in flexplate) and went to tighten the nuts on the tc studs, but noticed that there was a 1\4" gap between the tc and fp. I tightened the nut and it slid the tc forward away from the pump that 1\4". Is this OK or is something off? Thanks
Old Apr 10, 2012 | 07:08 PM
427 fordman's Avatar
427 fordman
I haven't worked on these trans at all, but I'd think that is right. On all other I've worked on it does pull out a little bit. When I set up race cars they need to pull out 1/8 to 1/4 inch to be right.
Old Apr 13, 2012 | 06:59 PM
fordman67's Avatar
fordman67
Actually that is great! If you had no gap or was in a bind that is bad.pulling converter up to fp is a good sign.
Mar 13, 2021 04:55 AM
condor13
1983 - 2012 Ranger & B-Series
Aug 15, 2013 09:59 AM
Roark
36
Aug 21, 2009 06:56 AM
F-150Guy
Jun 6, 2005 06:23 PM
moritz1024
1978 - 1996 Big Bronco
Sep 4, 2004 07:40 AM
