Speed Sensor Recall Notice
Old Apr 9, 2012 | 11:23 PM
Talyn's Avatar
Talyn
Did anyone get a speed sensor notice?
I'll have to dig out the sheet, but I got a recall notice for my speed sensor.
Odd thing is, my speed sensor is reading some crazy stuff too.
I was going though my scan gauge when cruising 70 on the highway, little did I know my truck thought i was doing 150.
Old Apr 10, 2012 | 12:08 AM
madpogue's Avatar
madpogue
Oh admit it; you were doing 150...
No notices yet, and I know we're in the database 'cuz we got notices for the cruise / master cylinder thing for both trucks.
Old Apr 10, 2012 | 06:53 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
If this is like the cam sensor recall, I'll throw it in the trash too.
Go to a scrap yard and find a new/used sensor before getting a brand new one from Ford, if it's the quality of their cam sensors...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 10, 2012 | 07:19 AM
fordpride's Avatar
fordpride
I had to replace mine last year and I went through 3 before I got one to work right
Old Apr 10, 2012 | 08:33 AM
Talyn's Avatar
Talyn
I'm getting like 24mpg on the highway at 65-70. I'm not touching sheet.
Old Apr 10, 2012 | 09:46 AM
msmenne17's Avatar
msmenne17
Same here. Mine was cutting in and out and causing the truck to shut off at highway speeds. It started back up right away, but was getting worse.
I tried several parts store ones. They were crap. I stopped at a stealership in SD while we were on vacation and got one that worked sort of. My speedo used to be dead on. Now, it drops by about 5mph once in a while at 65 and above. Cruise doesn't work because of it.
I'll have to find a dealership this week and see what other recalls need to be done. I just put a CPS in two weeks ago. Same thing as I've read elsewhere. The gray ones are crap. Last 6 months at most. Finally found a black BWD at Advance Auto Parts. So far so good.
Old Apr 10, 2012 | 12:32 PM
Talyn's Avatar
Talyn
I'm not talking about the cruise control sensor.
This was a different TSB.
I'll have to dig it up.
Old Apr 10, 2012 | 12:36 PM
msmenne17's Avatar
msmenne17
The VSS affects cruise control. My CC worked (as in it would turn on), but it wouldn't hold a steady speed and was jerking because the VSS wasn't sending a consistent speed.
Old Apr 10, 2012 | 12:43 PM
Talyn's Avatar
Talyn
Gotcha.
I'm getting a consistent reading on the dash, but the computer is seeing me as going faster.
I wonder whats up with that?
I know it used to read the correct speed on my scangauge.
I'm not having any Cruise Control issues either.
Old Apr 10, 2012 | 03:44 PM
stainlessstroker95's Avatar
stainlessstroker95
Could your default setting be off on your scan gauge? I was messing with mine and i got it to read some wild mph numbers. Under tire size it is sopost to be 100.
Old Apr 10, 2012 | 08:09 PM
F350-6's Avatar
F350-6
Scan gauge doesn't read MPH does it?
Or find you a friendly Ford diesel tech that will go ahead and just hand you the recall parts and enter your VIN in the computer. He get's paid by Ford for his effort (since he's typically getting underpaid for recall work anyway) and you get your VIN off the list so they stop sending you those stupid notices. You also get a free CPS to carry around as a spare.
By the way, do you happen to have any scan guages left over from the last group buy? Or have another group buy planned soon? Turns out I need another one.
Old Apr 10, 2012 | 08:12 PM
427 fordman's Avatar
427 fordman
Chris, my scangauge reads exactly the same mph as my speedo.
Old Apr 11, 2012 | 02:46 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I'm having what I believe to be VSS issues on my F-150. Seems to be the same VSS as my PSD has. Get above ~65mph and the speedo starts going crazy, bouncing between 60-85mph. It has a new parts store VSS, all new parts in the rear end, and a good pigtail. Unplugged the ABS module behind the glove box and the speedo is perfect now. Gonna investigate this VSS recall a bit.
Old Apr 11, 2012 | 03:32 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Hint, hint:
ALL vehicles are like that.
Makes you drive slower than you think you are going.
Seriously...
__________________
Old Apr 11, 2012 | 04:07 PM
superduty4x4's Avatar
superduty4x4
Try an OEM sensor, sometimes the parts store units are kind of wonky.
