Vacuum Elimination and Computer Issues
Old Apr 20, 2012 | 09:22 PM
  #46
1983F1503004x4's Avatar
1983F1503004x4
Originally Posted by MOFORDF150
Ok guys, I have the truck running. Had to replace the turn signal switch, that sucked.
The choke does not open and then engine races. Any ideas?
If the engine races after you've got it started, and the choke doesn't open, and your electric assist is/or isn't wired up, then it sounds to me like your thermostat on your carb for your choke isn't getting enough heat.
Is your choke stove hooked up?
Is the choke rod bent?
Old Apr 20, 2012 | 09:32 PM
  #47
MOFORDF150's Avatar
MOFORDF150
What is my choke stove? The rod is bent. I assume it worked for the previous owner. Could it be a vacuum leak?
Old Apr 20, 2012 | 10:56 PM
  #48
Gary Lewis's Avatar
Gary Lewis
If the choke doesn't open you probably don't have it connected properly. As was said, it should be connected to the stator connection on the alternator. Check for about 7 volts at the choke when the engine is running.
As for the engine racing, it is on the fast idle cam since the choke hasn't come off. Fix the choke and I think you'll fix that problem as well.
Old Apr 20, 2012 | 11:02 PM
  #49
MOFORDF150's Avatar
MOFORDF150
No cant be it on the choke. I did what everyone said and put my choke on the stator, getting the 7and volts. Might just have a bad choke spring. Any way to check?
Old Apr 20, 2012 | 11:09 PM
  #50
Gary Lewis's Avatar
Gary Lewis
Yes. Take the wire from the alternator off at the choke and put your DVM's red lead on the connector you took the wire off of and the black lead on ground. With the meter set in low ohms mode you should see several ohms resistance. If not either the heating element is bad or the ground wire is off the choke.
Old Apr 21, 2012 | 06:01 AM
  #51
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Gary, 4180's don't have a ground wire, just a single bullet-like connector.
They ground through the carburetor itself.
MOFORD,
If it is racing and the choke is closed either the choke cap is incorrectly adjusted, the fast idle cam is sticking, or you have a vacuum leak.
-Has it ever been tinkered with? ... Are there screws holding it in place, or are there three conical anti-tamper nubs securing the stamped steel 'collar' holding the choke element in place?
There are hash marks on the periphery of the bakelite housing.
I don't know what the calibration code calls for on an F-150 with Cat's. (mine is two lines tight)
There should be a small aluminum tag affixed under one of the screws of the vacuum diaphragm cover with a Motorcraft number stamped on it. This can be decoded.
Also, there is a Holley build number stamped into the front of the choke horn.
Holley has all the jetting and adjustment numbers on pgs. 15-16 of a pdf on their website.
If your choke element is burned out (open circuit between the carb body and the choke wire terminal) I'm pretty sure I have a spare.
If your EGR plate gasket is burned through beneath the spacer it will rev high on choke. Try spraying a little carb cleaner around the base and see if the engine runs different. Felpro sells the gasket for around $10.
Old Apr 21, 2012 | 08:20 AM
  #52
Gary Lewis's Avatar
Gary Lewis
Jim - I forgot we are talking about a 4180, and even had I remembered I wouldn't have remembered that there is no ground wire.
Glad you caught that as it makes a huge difference on fixing the problem if it is burned out due to the screws, as you mentioned.
Old Apr 21, 2012 | 08:29 AM
  #53
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Gary,
I wish I had a 'before' photo of my old carb.
There were no digital cameras back then.
IIRC, that Hot Rod article reprinted on FLEMWORLD shows the anti tamper screws and how to cut a slot in them with a Dremel tool so you can remove them to adjust or replace the choke element.
They are 8-32 I think.
Old Apr 21, 2012 | 08:30 AM
  #54
bruno2's Avatar
bruno2
Carb cleaner or Brake cleaner is excellent for finding vacuum leaks.
Old Apr 21, 2012 | 08:37 AM
  #55
Gary Lewis's Avatar
Gary Lewis
Originally Posted by ArdWrknTrk
Gary,
I can post pics of my 4180 if needed, Jim, as I don't think its screws have been changed out. And, I have that link bookmarked.
Ar. Hillbilly
Nov 3, 2016 08:12 PM
79250ranger
Jan 2, 2015 12:58 PM
tuckerjw
Mar 23, 2008 01:38 AM
outlaw128
Dec 6, 2007 02:41 PM
claw4
1978 - 1996 Big Bronco
Jan 9, 2005 04:44 PM
