Vacuum Elimination and Computer Issues
Old Apr 10, 2012 | 10:18 AM
whisler's Avatar
whisler
I'm with Bruno2 and Gary on this; keep it as simple as possible. As I a paint chemist I had to deal with this EPA stuff all the time, and most of it is poorly thought out BS.
When it comes to pollution control, the most important thing is to control oxides of Nitrogen (NOx). Contrary to the EPA theories, which stated that we must control Hydrocarbons to control smog, The National Academy of Sciences in an EPA/DOE commissioned study, found that control of hydrocarbons is impossible because their sources are 70% natural (aka trees and vegetation).
The NAS told the EPA to control the trigger to the reaction, which is NOx, to control smog. EPA didn't like this (meant backtracking on previous regulations) and refused to publish the study so NAS published it themselves (550 pages)
The parts that control NOx are EGR and a high quality catalytic converter. The parts that control hydrocarbons are essentially like peeing in the ocean; it might make you feel good but it doesn't accomplish anything
Old Apr 10, 2012 | 12:51 PM
82f100460's Avatar
82f100460
In my industry (HD Gas Turbines), we only control NOx and CO as byproducts of the cumbustor. We pay attention to Hydrocarbons only in relation to our fuel spec used.
Old Apr 10, 2012 | 04:55 PM
ctubutis's Avatar
ctubutis
Where can we see verification/validation/substantiation of this? Do you have any links we can take a look at for ourselves?
Old Apr 10, 2012 | 05:43 PM
1983F1503004x4's Avatar
1983F1503004x4
I agree. I'd like to see it myself, just out of interest.
Not calling you out or saying your a liar or anything whisler, and we all know a lot of EPA is BS. But, a lot of it IS good too.
Old Apr 10, 2012 | 05:53 PM
whisler's Avatar
whisler
My Technical Director had a copy of the published work in the late '90s. That book and the discussions that we had about the study are the source of my information. I can't say that I read the entire 550 pages but I believe he did. I did, however, read important parts of the study and the conclusions of the NAS.
Since he retired quite some time ago and moved to Georgia, I don't have the book in my possession but I will try to find the title.
Old Apr 10, 2012 | 10:42 PM
whisler's Avatar
whisler
Did not find the book title in my search but found some supporting info.
Untitled Document
In this link I find one bit of contradiction, in that they refer to the high level of natural HC in Atlanta GA due to the highly vegetative nature of the area, but then use a reference to remote areas as having low levels of HC. In my neck of the woods, remote area are highly vegetative and so would be high in natural HC. Possibly some PC thinking here!
Air pollution emissions
This link states the same conclusion that the study showed, but from someone from outside the US.
I haven't contacted my old boss for several years but will try to get in touch and see if he has the book still.
Old Apr 11, 2012 | 06:12 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Didn't this thread go off on a tangent???
The OP is going to need a vacuum line run to the climate controls as well.
I had no idea a 351 H.O. would be found in an '86 F-150.
Thought the Duraspark II, Non-Catalyst engines would only be found in >8k GVW vehicles.
The only computer in this system is the ignition control module.
EGR is really only there to reduce combustion temperature (NOx) and control lean knock under cruise and part throttle acceleration.
Old Apr 11, 2012 | 06:57 AM
Gary Lewis's Avatar
Gary Lewis
Good for you, Jim. When I saw there was another post in this thread I chuckled about how far afield we've gone.
As for the HO, one of the trucks I parted out was an '85 light-duty F150 with a 351 HO. It was DS-II with a cat, but no EEC. However, it seemed to have more plumbing than the 351W with DS-III & EEC that was in the '82 Explorer. It was a real rat's nest of hoses, check valves, switches, and such. I can understand the OP's desire to simplify things.
Old Apr 11, 2012 | 07:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Gary,
Good to know the H.O. was available in a light duty as late as '86. I was unaware of that.
MOFORDF150,
As has been said certain vacuum lines; like the distributor, PCV valve, brake booster, climate control and transmission modulator (if you have one) are going to have to stay.
If you want to lose the EGR be prepared to buy a kit and recurve the distributor.
The EGR won't work correctly without the thermostatic valve you already removed anyhow...
You likely will lose power and mileage in the process.
I don't think there's anything to expect from your computer.
In fact, I don't know what computer you could have if it's a DSII system.
Hope you get it sorted out and your new F-150 will reliably get you and your motorcycle to your riding spot!
Old Apr 11, 2012 | 07:49 AM
1983F1503004x4
Gary,
87 was the last year for a carburetor in Ford trucks. 351 HO 4v and 460's were the only ones left, and they had DSII.
Old Apr 11, 2012 | 10:36 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I understand that '87 was the last year for carbs. (I have one)
What I didn't realize was that an H.O. could be found (with Cats) in a light duty truck this late.
I had thought it was only 'Heavy Duty' vehicles (with Non-Catalyst) that had a carbureted DSII by this time...
Old Apr 11, 2012 | 06:16 PM
bruno2's Avatar
bruno2
My 87 Bronco has the H.O. and DSII also Jim. I would think the Bronco would be considered light duty like the F 150.
Old Apr 11, 2012 | 07:27 PM
  #28
Citizenrain's Avatar
Citizenrain
Im working on a very similar project, taking a bad 351w 2v out of my 84 F250 and swapping in a 79 351w without emissions (not even the ports on the back of the heads for the extra EGR stuff). The engine came out of an 85 F-150 Explorer that had already been converted over so Im just directly swapping everything from the 85 to my truck. I've been taking some pictures and will be vacuum eliminating what I can and swapping over the wiring and throttle linkage this weekend, so hopefully I can show you all finished pictures of the process.
Old Apr 11, 2012 | 08:12 PM
  #29
MOFORDF150's Avatar
MOFORDF150
Thanks Everyone
You all are great once I let you get going. learned some good stuff. Decided to just remove smog stuff and stay with the egr, it was still intact so I will re-run and leave it there. The rest was a pile of semi-plugged goop so it went by the wayside. I will be slapping on the carb tomorrow. Let you all know how I did.
I do appologize for my rant, looking back it made me sound like a little girl. I have put in some hours at work and am a little b--chy. Thanks for all the good info.
Old Apr 11, 2012 | 10:04 PM
  #30
Gary Lewis's Avatar
Gary Lewis
What rant? (The nice thing about my age and/or genetic disease is that I can't remember that I can't remember. ) Actually, good apology and it is accepted. All of us get that way at times.
And, good plan on the vacuum and EGR. Please let us know how it goes.
