brake pedal not returning fully
Old Apr 9, 2012 | 06:24 PM
Munch's Avatar
Munch
the brake pedal in 1978 f250 does not fully return. bleed brakes a few times with the perportioner valve held open for the fronts. the pedal comes back but still has another inch to go and you have to pull it up with your foot. the inch that does have to be pulled up does feel like you are moving the mc. is the mc bad?
Old Apr 9, 2012 | 07:59 PM
Crazyfirefighter's Avatar
Crazyfirefighter
try the return spring
Old Apr 9, 2012 | 09:26 PM
Munch's Avatar
Munch
has there ever been a return spring on a 1978 f250 4x4 with a manual tranny?
Old Apr 10, 2012 | 12:41 AM
wyckedcombo17's Avatar
wyckedcombo17
My clutch has return spring under the dash, but no brake pedal should have a return spring under the dash. How old is the MC? There are springs inside the MC to return the pedal and take hydraulic pressure out of the system.
Old Apr 10, 2012 | 01:44 AM
ChiefM's Avatar
ChiefM
Could it have the wrong length rod?
Old Apr 10, 2012 | 11:20 AM
Munch's Avatar
Munch
rod length is stock, mc is 2 years old.
Old Apr 10, 2012 | 12:27 PM
77F350RangerSCS's Avatar
77F350RangerSCS
My 1977 F250 pedal was not returning at all, holding the brakes on, replacing the brake booster fixed it. Maybe yours is starting to fail or maybe just the bell crank linkage pivots need to be cleaned/lubed.
Old Apr 10, 2012 | 03:39 PM
shadowviper12345's Avatar
shadowviper12345
Why does it matter? Are the brakes not letting off all the way or is it just that your brake lights wont turn off? If its the latter, I just used a bungee coed to get the brake to come all the way back.
Old Apr 10, 2012 | 10:50 PM
Munch's Avatar
Munch
the brake lights are not a issue, that is adjustable. The brakes are dragging when I dont pull up the pedal. I should change the brake booster, it is the origional that came in it from 1978.
Old Apr 11, 2012 | 09:11 AM
77F350RangerSCS
Do booster and master cylinder as a unit for the few extra bucks it's worth it.
tvliftcabinet
Jun 28, 2017 03:47 PM
zoomeroo
May 3, 2016 02:32 PM
cfrives3
13
Mar 24, 2008 03:56 PM
surveyor
Mar 15, 2004 04:43 PM
ExplorerRon
Jun 10, 2003 04:09 PM
