Turning Down High Idle EFI 460
I have a 1988 F250 with a EFI 460. The top end was recently rebuilt with a rv cam. Currently it idles 1750-2000 rpm's cold and wont come down when it warms up. I am thinking the reason my truck is idling so high is because of all the vaccume lines that are unhooked. I need a good vaccume diagram so Ican replace all of the lines. Also, the coolant temp sensor is disconnected because the dash gauge is not reading. I also wanted to know where the coolant temp sensor is so i can hook it back up.
Thanks,
Matt
Thanks,
Matt
on
Oh.. that could be a problem.
Well yeah, so plug them back in. It doesn't matter where you plug them in either as long as the lines fit, vacuum is vacuum.
Dash gauge has it's own sensor.. a single wire thing right behind the #5 injector, the engine coolant temp sensor is a 2-wire in the thermostat housing.
Band-aid fix at best. There is a reason why there is an IAC in the first place. Fix the root cause, then move on. I highly suggest you never call that Ford service place ever again. Bad advice IMHO.
Duct Tape Racing
02-04-2018 06:22 PM
Masonlane460
09-23-2016 01:31 PM
RebusCom
09-21-2013 04:28 PM
