How to test for leaking injector?
Old Mar 31, 2012 | 05:12 PM
brcwelding's Avatar
brcwelding
As the title says i was wondering how to tell if i have a leaking injector.
Old Apr 7, 2012 | 12:34 PM
brcwelding's Avatar
brcwelding
Maybe i should have been more detailed. I have an 88 f250 351w .
Old Apr 7, 2012 | 01:26 PM
subford's Avatar
subford
You could pull the fuel rail and just watch and see.
If cylinders are filling with gas while the truck sits then you may have a leaking injector.
If it takes forever cranking and a HUGE cloud of black smoke comes out when it finally starts then you may have a leaking injector.
Old Apr 8, 2012 | 08:00 AM
brcwelding's Avatar
brcwelding
It cranks over for 3 or 4 seconds before starting but no cloud of black smoke.
Old Apr 8, 2012 | 08:30 AM
subford's Avatar
subford
You may have a bad check valve in the high pressure pump on the frame or a leaking fuel pressure regulator going back to the tank then.
Any reason as to why you asked about a leaking injector?
Old Apr 8, 2012 | 03:55 PM
brcwelding's Avatar
brcwelding
I was thinking possibly the injector was leaking causing the system to lose pressure after i shut the truck off.And i thought that could be causing the truck to have to cran longer because it had to build up pressure in the system. I could be wrong though.
Old Apr 10, 2012 | 07:21 PM
brcwelding's Avatar
brcwelding
Subford, any idea how to test the high pressure pump and fuel pressure regulator to see if they are bad?
snakedoc
Sep 20, 2012 08:37 AM
88f1504x4
Apr 22, 2011 08:11 PM
tobacco farmer
Apr 21, 2010 04:34 PM
fordpride
Mar 2, 2010 06:06 PM
mike2003lhs
Jan 31, 2008 10:24 PM
