I think you may be right Blade I charged the batts fully and cranked the truck with the scanner hooked up and got a reading of 400 + psi on the icp but only a 15% reading on the ipr. So I'm gonna take your advice and pull the ipr tomorrow.I will let you know
OK it has been a few months but I got off from work long to work on my truck. I have figured out that the HPOP, ICP and IPR went south. Pulled IPR found metal in the screen. Unplugged icp still crank and no start. So I would like to thank everyone involved for their input. If it helps I can post pics on removal of HPOP on early 6.0. Will keep all up to date. Thanks again
All parts for my truck come from NAPA , dealer or lately throughbread diesel. I hoping no metal made it in the injectors but to be sure im gonna remove and flush out the oil rails and place a magnet to see if any metal shavings made it. 5 injectors have less then 30k on them.
