390 noise
Old Apr 9, 2012 | 09:29 AM
jman68's Avatar
jman68
390 noise
I have a 66 F-250 with a 390 in it. It has developed a noise that I can't seem to diagnose. Once the engine is warm, if you let off the gas at about 40-45MPH to maintain that speed, there is a wrapping noise coming from the engine. At idle I hear nothing and while accelorating I hear nothing. Any ideas what this may be and where to start? Thanks.
Old Apr 9, 2012 | 09:52 AM
1972RedNeck's Avatar
1972RedNeck
It may be backfiring on deceleration? What is your timing set on? I would set your timing on 10 - 12 degrees and see if that fixes it.
Old Apr 9, 2012 | 04:48 PM
daveengelson's Avatar
daveengelson
Might try blocking tires w/ tran's in neutral see if able to observe from under the hood. Wonder if belt, or pulley acting up at a particular rpm.
Old Apr 9, 2012 | 07:23 PM
Wyatt66f100's Avatar
Wyatt66f100
Wrapping noise? what does a wrapping noise sound like?
Old Apr 9, 2012 | 07:51 PM
daveengelson
Curious myself!! If it's a 'wrappping' as in back pressure from exhaust agree w/ redneck. Not an authority, but seems it could be timing; although, did have a simular issue and turned out to be carburation, believe due to my setting mixture too rich and it was dumping excess fuel into the hot exhaust manifold.
Old Apr 9, 2012 | 08:32 PM
1972RedNeck
A vacuum leak can also cause backfiring.
Old Apr 9, 2012 | 09:43 PM
garbz2's Avatar
garbz2
Wrapping noise on decel is a rod bearing....or you have one or two bent push rods
Garbz
Old Apr 10, 2012 | 06:53 AM
jman68's Avatar
jman68
Thanks All. Sorry about the "wrapping" descripion. I will try to describe it as best I can. It is like hitting on something relatively hollow with a hammer. It doesn't do it as much on decel as it does at constant speed. My first thought was bearing. Before I went down that road, I wanted to see what you thought. Thanks for the replies, I now have several options to explore.
TheProfessorofTOOL
Modular V8 (4.6L, 5.4L)
Apr 23, 2013 08:31 PM
muleriderdave
Feb 10, 2010 11:41 AM
Andywk
Dec 8, 2005 07:12 PM
matt0588
Nov 19, 2003 10:48 AM
