dana 60
Old Apr 6, 2012 | 06:00 PM
lafermedavid's Avatar
lafermedavid
dana 60
I was wondering if any body out there has messed with their inner seal,for the inner axle on their dana 60.Should or shouldnt I?How madatory is it.just wondering.thankyou all
Old Apr 8, 2012 | 05:00 PM
HIO Silver's Avatar
HIO Silver
It's prolly there for a reason!
Old Apr 8, 2012 | 05:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ask FTE member Mikeo0o0o0 to scan and post the following from the '73/79 truck parts catalog:
Illustration Section 40, Page 2 ~ Exploded view of all the Dana 60 rear axle internal parts.
The inner rear axle seal basic part number is 1175
Gaining access to this seal is not a fun nor EZ job, it's a PITA. If you don't know how, take it to a shop.
Old Apr 8, 2012 | 05:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's the illustration that Bill is reffering to.
Click on the .pdf link to view.
File Type: pdf
Old Apr 8, 2012 | 07:05 PM
Diesel_Brad's Avatar
Diesel_Brad
Unless it is leaking, there is no need to touch it
Old Apr 8, 2012 | 07:09 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Is this a rear or front? The rears I worked on only had wheel seals and the fronts had the inner seals. they aren't too bad, but don't do it unless they are leaking. Don't just do it cause you have a saturday to work on your truck.
Old Apr 8, 2012 | 07:21 PM
NumberDummy
Look at the pic Mike posted (pdf link) in post 4. The Dana 60 inner rear axle seals [# 1175] are a PITA to get to.
These are not called wheel seals. I've never heard or seen any such thing on any Dana 60, 61 or 70 rear axle.
If the OP doesn't know how, it may take him at least a WEEK of Saturdays (7 days) to R&R them!
Old Apr 8, 2012 | 08:51 PM
lafermedavid
dana 60 front inner axle seals
I pretty much had every thing out of the front axle,that is why I posted the ?I replaced the kingpins and lower bearings to both side of my knunkles.35 spline upgrade on outer axle.I decided to wait until they are leaking.Thankyou all for your advice and knowledge,I always appreciate it.Great to see your post Numbers Dummy,one thing is for sure your no Dummy,thanks Mike for the diagram.
Old Apr 8, 2012 | 08:59 PM
F-250 WARHORSE
Ok front axle. I look at mine and decide how bad they look if they aren't leaking, but if you want to do the inner seals then You have to pull the locking hubs, then the brake caliper then the bearings and bearing hubs then the spindles then the axle shafts then the front cover then the bearing caps over the carrier then the carrier then the front seals and they are a lot of fun to try to drive straight, they are stubborn. As far as a D60 rear, the only seals are the ones in the bearing hubs and the pinion seal, other than that there isn't any others I have ever found.
Old Apr 8, 2012 | 09:02 PM
lafermedavid
rear axle
I should have been more specific with axle location,the rear axle is a peice of cake compared to front Dana 60,my rear axle is complete.Im onto the front now.inner axle seal is the front dana 60,looks easy enough to replace but not at this time.
Old Apr 8, 2012 | 09:03 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Oh, so it's the front axle you're working on?
Here's the diagram for the Dana 60 front axle.
Again, click on the .pdf link
File Type: pdf
Old Apr 8, 2012 | 09:05 PM
F-250 WARHORSE
I looked close at that picture, I never thought these were that big of a deal, I might be confused, but pull the axle (5 min) pull the 2 nuts off the spindle (10min) then pull the hub/drum assembly and knock the seal out. I may be mistaken, but this isn't a huge deal. I look at a big deal like pulling a 18 speed transmission out of a Kenworth and rebuilding the auxillary and the bearings inside then putting a new clutch and re installing the transmission, that is a wek worth of saturdays.
Old Apr 8, 2012 | 09:26 PM
lafermedavid
diagram
thanks again Mike,F250 warhorse I thought the same thing,small enough ram and seals are out.special tool to replace,or be creative.Thanks to all.
Old Apr 9, 2012 | 06:58 AM
Stinky7-11's Avatar
Stinky7-11
This is what i thought from the start and ND is correct about the time frame, lol.
Seems like what you meant was a inner wheel bearing seal and that is no big deal, even easy if you have done it more than once. The inner axle seal is not the same and as others have said " If it ain't fixed, don't break it".
I could just be confused by that's what I get for lurking
Old Apr 9, 2012 | 07:42 PM
Blackfoot Big Block's Avatar
Blackfoot Big Block
The second diagram (front axle) shows the closed knuckle axle design.
The 1978 and 1979 Dana 60s were open knuckle. IIRC the closed knuckle design don't have the inner axle seal (near the ring and pinion). The open knuckle design do have that seal because that's what keeps the gear oil in the differential.
This is from long term memory so I could easily be wrong.
