Scared to do a cab swap on my dd
04-12-2012, 02:33 PM
How does the computer come out? I thought it slide out tawards the engine
04-12-2012, 03:13 PM
Quote:
Originally Posted by
rangergirl94
If you are having problems with that, then you will be screwed when it is time to swap a cab. just saying
04-12-2012, 03:35 PM
Drill out the hanger rivets and bolt them back on.
04-12-2012, 03:56 PM
The computer is not coming out its unbolted which is two nuts how does it pull threw with studs sticking out??
04-12-2012, 03:59 PM
You have to pull the rubber gasket that you removed the nuts from. THEN the ECM will come right out
04-12-2012, 04:02 PM
Nvm it was siezed to the metel sleeve sorry
04-12-2012, 04:04 PM
rangergirl94
so im no idiot
famous last words!
should be a piece of cake.
04-12-2012, 04:35 PM
on
rangergirl94
When I buy shackles they never ask if it 4x4 or 2x4 theres no way to put 3 inch springs on it?
It can be done, I thought you just wanted to swap part of the spring pack.
ClassicKidNick
06-07-2021 11:31 PM
66P51
05-29-2016 02:50 PM
khakushia
01-22-2012 07:16 AM
Weezman
04-01-2011 10:18 AM
Nathane
06-08-2006 11:11 PM
1987 ,
91 ,
96 ,
bed ,
cab ,
disconnect ,
f150 ,
f250 ,
ford ,
liner ,
paint ,
ranger ,
remove ,
rolled ,
swap
