Scared to do a cab swap on my dd
Old 04-11-2012, 02:06 PM
CletusSnow's Avatar
CletusSnow
CletusSnow is offline
Don't be scared it can be done, nothing is impossible. If you have wiring you want to transfer, play it safe and buy some of the plastic wire sheath and some zip ties in case any of the existing comes off or in case clips break. Plan it well and go for it.
Old 04-11-2012, 02:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I am curious to all of those giving the advise, how many have actually swapped a cab in a weekend?
Old 04-11-2012, 04:59 PM
rangergirl94's Avatar
rangergirl94
rangergirl94 is offline
How does the headlight **** come off with out breaking it lol
Old 04-11-2012, 05:47 PM
RJJP's Avatar
RJJP
RJJP is offline
Pull it out and look around it, there will be a grove, slide a pick or knife blade into the slot at the front (close to the dash) then slide it to the rear and the **** will slide off.
Old 04-11-2012, 07:36 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
I swapped a frame and it dang sure wasn't in a weekend ! !
Old 04-11-2012, 07:38 PM
Diesel_Brad
Exactly my point. Not saying the cab cant be swapped, but it is going to take more than a weekend for a NOVIS 1st timer.
I have swapped at least 15 cabs and I would be hard pressed to do it with air tools and a tractor to pic/set a cab
Old 04-11-2012, 07:42 PM
ncranchero's Avatar
ncranchero
That's what I'm talkin' 'bout!
Old 04-11-2012, 11:01 PM
rangergirl94
I guess ill have to try it then!! Lol
Old 04-12-2012, 12:10 AM
CletusSnow's Avatar
CletusSnow
That's why I said give yourself plenty of time. There's lots of otherwise simple jobs that have taken me a lot longer than I had planned because of running in to other snags. But she won't know till she try's and the only reason she can't say how long it will take is because she hasn't done it yet and I bet she ain't never not made it yet. Its parts swapping so all she really needs is time, its not like its a sight unseen job. This is America and we can do anything! So how about some encouragement! Lets get-r-done, if I was in Ohio, I'd gladly help.
Old 04-12-2012, 12:24 AM
RJJP's Avatar
RJJP
RJJP is offline
Agreed, 1 weekend well possible, isn't probable.
Old 04-12-2012, 08:23 AM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
If everything goes good, it is possable. I can remove all but the cab by my self in a day. Took a few more days getting the man power to move the cab! I also took the bed off so we did not have to huff it higher than needed.
On my friends cheby cab swap the bed was left on and that took more effort...... thats when some 10' 4x4 posts cam in to play to hold up the cab and sit it on the bed. He did it in a weekend.
Old 04-12-2012, 12:33 PM
rangergirl94
Well im a redneck and all my buddies drive chebbies and dodges which means I help them alot lol so they better help when the ford needs tlc lol
  #28
Old 04-12-2012, 12:39 PM
rangergirl94
Instead of starting another thread can any of you tell me if rear leaf springs off a 95 4x4 150 will fit a 96 2x4 150
  #29
Old 04-12-2012, 12:44 PM
RJJP's Avatar
RJJP
RJJP is offline
No, 4x2 uses 2.5" wide springs while 4x4 uses 3" wide, on the F150s, F250 and up use 3" on pickups 2 or 4.
  #30
Old 04-12-2012, 01:04 PM
rangergirl94
When I buy shackles they never ask if it 4x4 or 2x4 theres no way to put 3 inch springs on it?
Quick Reply: Scared to do a cab swap on my dd
