constant gas flow, even with engine off?
Old Apr 7, 2012 | 03:30 PM
PDXF250's Avatar
PDXF250
83 f250 460:
My truck wouldn't start a few weeks ago, but since I don't drive it regularly (and it's not licensed), I didn't mind.
So I finally was able to check for the filter maybe being an issue or something else (first decent day in Portland, when I'm not at work, in a LONG time).
Couldn't find any filters on the frame/fuel lines.
So I did the next logical thing in my mind. I disconnected the fuel line AT the carb, and checked to see if I had any pressure.
Thats when something weird happened. As I unplugged the fuel line, gas was POURING out of the hose. The engine wasn't on, and I hadn't turned it over in weeks.
Now, maybe I'm totally wrong, but I would assume that isn't normal. It would explain why my engine wouldn't stay running (super flooding).
What could cause that? A bad fuel pump? Being stuck open?
Keep in mind, I'm on a hill, nose facing down.
Old Apr 7, 2012 | 04:11 PM
PDXF250's Avatar
PDXF250
I tried it with the battery disconnected, hypothesizing that maybe there was power to the fuel pump (?) but it didn't make a difference.
I'm going to try it again, this time tweaking the relays. Maybe they're making it stick open? Who knows.
Old Apr 7, 2012 | 04:12 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Your on a hill, facing down. It's called gravity feed. And once it starts good flow it'll continue to siphon.
Old Apr 7, 2012 | 04:13 PM
PDXF250's Avatar
PDXF250
wouldn't that flood the carb?
Old Apr 7, 2012 | 04:25 PM
82f100460's Avatar
82f100460
83 460 so I'm assuming it's a mechanical pump and not EFI?
If your float valves in the carb are working properly it shouldn't matter if there is fuel to the carb. There is fuel there all the time when it is running and the flow is controled by the bowl floats.
Is it under pressure or just running out? More importantly does it develop pressure when it's cranking?
Old Apr 7, 2012 | 04:36 PM
ctubutis's Avatar
ctubutis
I would next check for spark
Right...
Just like a toilet bowl tank.... Your house has water pressure all the time, the valve controlled by the floating ball on the end of the rod controls the flow of water into the tank.
Sounds to me like what Matt said - a siphon. Personally, I wouldn't consider that unusual or a sign of anything bad.
Since you obviously have fuel to the carb, I would check for spark... Pull a plug wire from a plug, insert a screwdriver into the boot, hold it near a good ground as somebody turns the key as if to start it. You should see a strong, blue spark.
Kevin - Some of these 460s have mechanical pumps, others - even carb'd ones - have electric. Looking up fuel tank senders for 460s is a big PITA for this reason....
Old Apr 7, 2012 | 04:41 PM
82f100460's Avatar
82f100460
yeah I was trying to remember what they call it. I think it called the High Temp package or something like that on the 460's. Those had the electric pumps and the funky fuel transition right at the carb by the distributor.
Old Apr 7, 2012 | 04:47 PM
82f100460's Avatar
82f100460
found what I was trying to think of. It's called the Hot Fuel Handling package. There is vapor seperator just before the carb.
Old Apr 7, 2012 | 05:20 PM
PDXF250's Avatar
PDXF250
Thanks all.
It just sounded weird to me (as I'm not a carb person, I'm a FI person...in that I like that my Volvo is fuel injected..hehe).
I'm thinking, based on what I skimmed on here, what was said here in this thread, and what I found out at a local auto parts store, that it could be the fuel pump (mech) is gone or going.
So it's back to the truck engine compartment i go!
Old Apr 7, 2012 | 06:36 PM
82f100460's Avatar
82f100460
Huh??? I'm not sure what you read here that led you to believe it's a fuel pump problem!!!
You were asked it it has a mechanical or electric fuel pump so that you could run some simple tests to rule that out.
Based on your original post, you stated you disconnected the battery to remove power to the pump. Now you state the parts store has told you it's a mechanical fuel pump problem.
You need to run some basic tests to see where the issue is.
Or you can go to the parts counter and throw parts at it until it runs.
Old Apr 7, 2012 | 06:54 PM
PDXF250's Avatar
PDXF250
sorry, I missed those posts (I only got a single link that took me to a post and I responded to that, plus what i read on a "search" function) and didn't have time to re-respond to the posts updating what I did.
throwing money at it is incredible fun. When I drove it, every time I would pass a gas station, I threw money at it!
Old Apr 7, 2012 | 06:56 PM
PDXF250's Avatar
PDXF250
It's mostly running out (like it is draining), until I crank it. Then it comes out with greater gusto.
Old Apr 7, 2012 | 06:58 PM
PDXF250's Avatar
PDXF250
As I understand it, if there is a mechanical fuel pump, it should be easy to see on the engine block. So far I'm not finding anything.
I find the lines that from from under the truck (from the tanks) to a filter/splitter (1 in, 2 out). That goes to the carburetor.
I'll be back in a second to see if the spark issue happens (its a little hard to do it by myself).
Old Apr 7, 2012 | 07:01 PM
82f100460's Avatar
82f100460
I hear that...
What I would suggest is start very basic.
Every engine needs spark and fuel...so start there.
See if you have spark, at the right time of cource...and see if you have fuel.
You know you have fuel to the carb...just don't know if you have enough of it (i.e. is your pump working)
Take the air cleaner off and look straight down the throat of the carb with a flashlight. Stroke the accelorator a couple time all the way. See if you have a good strong stream of fuel squirting into the carb.
If the truck has been sitting for a long time...check to see if it smells funky.
If you got gas sqirting in the carb...then that's a good start. Check that your choke is funcitoning properly as long as your there.
Next you would move on to see if you have spark.
Once you narrow it to fuel or spark...then you can further narrow it down to why one of those is not working.
If you feel it is flooding...not based on the fuel coming out of the fuel line, Then hold the accelerator pedel to the floor as you crank it
Old Apr 7, 2012 | 07:02 PM
82f100460's Avatar
82f100460
perfect!!! then you don't have a fuel pump problem. Good job, that's possiblity is eliminated.
