Every engine needs spark and fuel...so start there.
See if you have spark, at the right time of cource...and see if you have fuel.
You know you have fuel to the carb...just don't know if you have enough of it (i.e. is your pump working)
Take the air cleaner off and look straight down the throat of the carb with a flashlight. Stroke the accelorator a couple time all the way. See if you have a good strong stream of fuel squirting into the carb.
If the truck has been sitting for a long time...check to see if it smells funky.
Of the suggestions, this is (as of right now) the only one I can answer (fixing dinner). The gas smells like gas.
There's no hint of turpentine/bad gas in it.
If you got gas sqirting in the carb...then that's a good start. Check that your choke is funcitoning properly as long as your there.
Next you would move on to see if you have spark.
Once you narrow it to fuel or spark...then you can further narrow it down to why one of those is not working.
If you feel it is flooding...not based on the fuel coming out of the fuel line, Then hold the accelerator pedel to the floor as you crank it
If it turns out to be something in the ignition...I could be a long list of things. Capacitor is one sure.
Go back a step though. You found that you have gas to the carb. But you have not determined if the carb itself is functioning properly to distribute the fuel to the intake/engine.
Try what I said earlier about pumping the gas and looking for fuel squirting down the throat of the carb.
The capacitor is there only to remove ignition-caused noise from the radio, constant, rhythmic popping in this case.
There is one by the voltage regulator to remove alternator whine, too.
How would a failure there cause an ignition problem? I don't think it can; cripe, remove the thing(s) entirely if ya want (from an engine that runs) and I'll bet the ignition system doesn't notice.
oh ok....I was thinking of the old points type distributor that had to have the capacitor there for fire the coil when the points opened. I just assumed it was there to do the same thing.
Duh...I guess that's the job of that little box over on the fender isn't it? I don't even have a radio....I guess I definately don't need that thing then do I?
I think that thing on the points was called a condensor too....not a capasitor. condensor, capasitor...what the hell's the differernce
I don't know... My 1970 Mustang/351Wheezer had points & condensor, my parents got a new car in 1977 that had a DS2 ignition and I sold the Mustang in 1990, that was the last time I'd ever dealt with that.
Early capacitors were also known as condensers, a term that is still occasionally used today. The term was first used for this purpose by Alessandro Volta in 1782, with reference to the device's ability to store a higher density of electric charge than a normal isolated conductor.<sup id="cite_ref-6" class="reference">[7]</sup>
you may not be getting fuel into the bowl, either due to a clogged filter or the float stuck shut.
you should have the holley 4 barrel on there I think. If you do, there should be a screw on the passenger side of the bowl. This is there to check bowl level. take that out and see if there is any fuel in the bowl.
If there is not then you know one of those 2 things are bad.
If there is fuel in the bowl...then you may have a bad accelerator pump.
Try this before you do anything. Pour some good gas down the the throat of the carb. See if she will try to start, or even start. This will confirm you not getting fuel into the engine as the problem.
actually, I replaced the (incorrect) carburetor with an edelbrock.
I did get it to kick over with starter fluid. but for a split second.
Sounds like you're getting it narrowed down to a carb issue then. I'm not familiar with how to check bowl level on the Edelbrock's. Not too sure how to check much of anything on those to be honest.
Ahh...looks like I'll have some reading to do tomorrow. I wonder if it's idle air screws, or something similar.
Thanks for all the help. There aren't too many screws to tweak on the carb (and my instructions are in the truck and I'll get them in the morning).
I like how this is potentially getting easier to fix...but it's annoying that I'm having to fix it. Heh.
Ah...owning old cars...
Ironically, I'm potentially buying an even older car, which will require a lot more repair work on it to make it drive able. But at least I'd be buying it KNOWING and EXPECTING to do it.
Well good luck with it. There are many on here that are Edelbrock experts so maybe one of them will see the thread.
I don't know a lot about them but I wouldn't guess it's as simple as a screw adjustment. If you're not getting fuel down the throat when you strock it, that's a problem. Those carbs have an accelertor pump just like the holleys. I think all carbs have to have them...get that initial squirt of gas to get the engine rpm up so that vacuum can go to work and do the rest.
