constant gas flow, even with engine off?
Old Apr 15, 2012 | 09:11 PM
  #46
PDXF250's Avatar
PDXF250
Originally Posted by 82f100460
I believe you may have to take it to start tO energize the pumps. They get power while in run only when there is oil pressure...it's a safety interlock
Hm...when the pumps hum, wouldn't that be the pumps working?
I don't remember, is there a safety switch (or something??) on the oil pressure switch doohicky? I replaced that already, but maybe there's a reset button?
I have already checked, just to mark it off the checklist, the um...thing that if the truck is upside down it shuts it off. I'm totally spacing on what it's called even though I'm sure I just said it. I keep thinking ground fault interrupter, but thats not it.
Old Apr 15, 2012 | 09:24 PM
  #47
ctubutis's Avatar
ctubutis
Yeah, that safety system exists, but the pump(s) should fir for a second or two just turning the key from OFF to RUN, this is to pressurize the system.
Old Apr 15, 2012 | 09:31 PM
  #48
PDXF250's Avatar
PDXF250
Yeah, and the ONLY fuel coming out of the line is gravity fed right now.
I'm REALLY hoping it's a relay issue (even though it has been replaced before...maybe it I needed to replace both (pump and switch)?)
Thanks all (esp you two) for having patience with me.
Old Apr 15, 2012 | 09:37 PM
  #49
ctubutis's Avatar
ctubutis
I can't really see the need to replace both if only one is having problems.
I'd have to re-read this entire thread but I see you asking about the intertia switch...
This is located passenger side, inside the cab, down near where the transmission tunnel & firewall meet.
It should have a round, red button or a white, rectangular one. There might be verbage on it explaining how to reset it.
That thing removes power to the pumps in the event of an impact, keeps from feeding gasoline to a fire.
But, again, I need to re-read this thread....
Old Apr 15, 2012 | 09:42 PM
  #50
PDXF250's Avatar
PDXF250
Yeah, Inertia switch! Couldn't for the life of me remembers it's name. I thought I re-set it, but who knows. Maybe I didn't do it right. If I was near the truck, I'd look into that and try it.
But with the carb off right now, it wouldn't do me a lot of good just yet.
Old Apr 15, 2012 | 10:00 PM
  #51
ctubutis's Avatar
ctubutis
Ok, I just read - well, skimmed - this entire thread again...
Correct me if I'm wrong, but....
We have determined you have electric fuel pumps, correct? You are used to hearing them when turning the key from OFF to RUN but you don't hear that now, right?
You got it to kick & chug with starting fluid, right?
If so, this is a fuel delivery problem, isn't that what we figured out?
Someplace around here there are pictures of the Hot Fuel Handling System wiring diagram. Probably multiple pictures, to be honest. i am not sure how much that system changed over the years, or if there were different configurations of it.
Do you have a multimeter (aka DVOM)? I would figure out if you're getting electricity to the fuel pump or not.
You can also use the Ohmmeter to figure out if the in-tank pump is burned out or not by measuring for continuity between the pump's positive lead and ground.
An open circuit means a burned-out motor.
I'm not sure what we're doing with relays, though, I skimmed through that part....
Old Apr 15, 2012 | 10:13 PM
  #52
PDXF250's Avatar
PDXF250
All that is correct. I'm mostly replacing the relays because they're not THAT expensive and they are 29 years old.
But how do you access the pumps (to check it? I do have a multimeter btw). I can feel where the fuel lines go, but I can't see/feel where any power lines go to it. I'll check it again tomorrow (assuming it's not raining when I come back from work).
Old Apr 15, 2012 | 10:35 PM
  #53
ctubutis's Avatar
ctubutis
The usual course is to lower (or maybe even drop) the tank(s).
Some people talk about it being easier to remove the bed but I don't buy that at all, just comparing the quantity and location and size of bolts tells me that.
Old Apr 15, 2012 | 10:40 PM
  #54
PDXF250's Avatar
PDXF250
ok, thanks. I figured I would have to do that (it's similar to accessing the reverse switch and OD switch on my Volvo. Just simpler to drop the transmission because you need to wrists that bend in 3 different directions otherwise).
Old Apr 16, 2012 | 07:59 AM
  #55
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Taking the bed off on a 26 year old truck will be a royal PITA, the cost of replacing the bolts will scare you. If you go that way, I would recommend cutting the nuts off and replacing them.
Old Apr 16, 2012 | 08:22 AM
  #56
82f100460's Avatar
82f100460
I guess I'm a little confused as to how we got this to be a fuel pump issue. If you go back to page 1, post #12, you state that when you were cranking the engine the fuel was coming out strongly leading us to believe that your pumps were working fine.
Old Apr 16, 2012 | 08:55 AM
  #57
PDXF250's Avatar
PDXF250
It was, but when I did it again, it wasn't.
Old Apr 16, 2012 | 09:08 AM
  #58
82f100460's Avatar
82f100460
gotcha...thanks
Mikey G
Aug 12, 2016 10:00 PM
Cory281
15
Feb 13, 2012 12:41 PM
78150custom
Oct 5, 2011 01:47 PM
keyul
May 15, 2011 10:38 AM
cwtex
Dec 19, 2003 02:46 PM
