please help...
Old Apr 7, 2012 | 02:54 PM
Liquid10Rider's Avatar
Liquid10Rider
please help...
just curious I'm not to sure where this came from but I was in the process of doing my glowplugs and putting everything back together and saw this plug just sitting there. Is it from the oem air box? I did take that out a while ago and put the 6637 filter in. https://lh3.googleusercontent.com/-m...0407-00020.jpg
Old Apr 7, 2012 | 02:58 PM
timmyboy76's Avatar
timmyboy76
air intake temperature. With nowhere to install it, i ziptied mine off to a line.
Old Apr 7, 2012 | 03:12 PM
Liquid10Rider
sounds good thank you for the quick response. Just wanted to make sure I wasnt forgetting that I removed it during this job. thank you again. does it have any effect on how the engine runs with not reading the correct intake temp?
Old Apr 7, 2012 | 03:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is virtually no difference between the temperature inside the filter and outside the filter. Like Tim said above, zip tie it out of the way you you will be fine. Your motor is more concerned with whether the outside temp is -20* or 120* more than it cares if it is 65* or 70*.
Old Apr 7, 2012 | 03:52 PM
BigAlsPSD's Avatar
BigAlsPSD
Pretty much true, although you do want to shelter it from too much heat from the manifolds. Mine is Zip tied to the brake lines. But I wouldn't want it laying near the manifold saying it is really hot out.
Old Apr 7, 2012 | 05:09 PM
ToMang07's Avatar
ToMang07
yeah, mine is zip-tied right next t the filter minder....somewhere under the filter.
MauleOne
Sep 17, 2010 06:37 AM
afonda
Nov 25, 2009 11:01 AM
outdoormaniac
38
Feb 9, 2008 11:15 PM
Night Bird
Dec 17, 2006 03:09 AM
RobertJohn
15
Jul 24, 2005 08:04 PM
