Trailer Wiring Harness
Old Apr 4, 2012 | 05:03 PM
FishingNut's Avatar
FishingNut
Anyone know what the part number is for the trailer wiring harness that would plug into the connectors on the underside of the truck on the drivers side near the hitch?
Old Apr 4, 2012 | 05:42 PM
B&LLandscaping's Avatar
B&LLandscaping
Part # BC3Z-13A576-A
It comes with all the mounting hardware and the direct connections. No instructions, but it's pretty straight forward.
I installed mine last weekend, and let me tell you, it was a thing of beauty to just plug right into the existing wiring harness with no cutting, splicing, taping, etc...
Old Apr 5, 2012 | 11:05 AM
FishingNut's Avatar
FishingNut
Thanks B&L!
Out of curiosity how long was the cable?
As I need to put it in front of the bed of the truck for my slide in (cabover) camper, not at the rear like you would do for a 5'ver.
Old Apr 5, 2012 | 11:16 AM
B&LLandscaping
Originally Posted by FishingNut
Thanks B&L!
Not long enough I'm afraid. I'd say it's maybe 5-6' long at best.
The connectors are just behind the rear outlet, next to the spare, they're nicely connected to the frame.
Maybe there's another set of connectors at the front? If not, I'm pretty sure you'll be forced to splice in a length of wire.
Old Apr 5, 2012 | 12:52 PM
FishingNut's Avatar
FishingNut
OK, Thanks again.
I will check for another connector but I am not holding my breath on that...
I guess I will just get a regular connector and splice it in further to the front of the bed and call it good.
Old Apr 5, 2012 | 12:55 PM
RobFlag's Avatar
RobFlag
Fishingnut,
I used this: 5th Wheel/Gooseneck 90-Degree Wiring Harness w/ 7-Pole Plug - GM, Ford, Dodge, Toyota - 9' Long Bargman Wiring 51-97-410
It's plenty long enough to run from the existing 7 way connector up to where I mounted it (above the gas filler door in the bed). It does not connect to the factory camper harness plugs but instead plugs into the factory harness that goes to the 7 way and then into the 7 way. Just a big long jumper cable with a connector in the middle.
On my Camper, I was able to use a 3 foot double female 7 way to connect between the jack in the bed and the jack on the camper. Works great.
Old Apr 5, 2012 | 01:01 PM
jasfaa's Avatar
jasfaa
You cant use that plug for the camper. You are supposed to run a much larger fuse from the battery to that camper plug in for constant power. Mine is a 150 amp fuse but anything over 40 will probably work. Plus the charge wire that is on the trailer brakes is only a 14 gauge wire. Way to small for a camper charge wire (you will melt it) Go online and look for a camper plug that ties into the wire along your frame rail or build one yourslef. They make kits for them but I have heard the wires are too short and you need to add wire to it anyway.
Old Apr 5, 2012 | 01:04 PM
jasfaa's Avatar
jasfaa
Originally Posted by RobFlag
Fishingnut,
The issue here is that if you have a camper and pull a trailer that is a lot of power on that small wire. Just my .02 cents. Look at that switched power wire. It is small and probably shouldn't be used for a camper and a trailer that requires power too. A boat trailer doesnt require power but other applications like my car hauler has two charge batteries on it as well as other items.
Old Apr 5, 2012 | 01:10 PM
RobFlag's Avatar
RobFlag
I had to add the plug to my 3 ft connector cable so wired that using the 10 gauge black/white for charge to the camper. Seems to be working.... Of course, the trailer I'm pulling isn't using any charge power since it's a two horse trailer with no power other than lights.
Old Apr 5, 2012 | 01:17 PM
jasfaa's Avatar
jasfaa
Thats just it. The next guy that has your truck might. How does a horse trailer stop? electric brakes?
I am just saying I have had several campers and the way to do it is not splice that power wire into the existing plug. Even for a Fifth wheel I would not want to do it that way but I guess its the same as pulling a trailer with the Fridge, batteries and everything else.
Old Apr 5, 2012 | 01:31 PM
RobFlag's Avatar
RobFlag
Yep, electric brakes. That wire is not connected to the Camper so shouldn't be impacted. As you said, it's not really any different that having a trailer with fridge ect. plugged into the bumper 7 pin. Wire gage on the harness seemed to be as large or larger than the factory harness.
BillBraskey
WTB - Parts & other
Jun 9, 2017 11:55 AM
X_archie
Crossovers
Aug 30, 2013 11:06 AM
mark460
Oct 15, 2011 04:08 PM
EMD_DRIVER
Nov 7, 2008 09:22 PM
cyclenut80
Feb 5, 2008 01:12 PM
