Trans help needed!
Old Apr 3, 2012 | 10:49 AM
fishthrower's Avatar
fishthrower
Trans help needed!
Hi All,
I have a new to me '77 F250 with a 460 and a C6.
I have searched the forum for a problem like mine, but nothing seemed very similar so I'm hoping to get some advice.
My trans takes forever to shift when I first start driving. Fluid level is completely full, and it goes into gear and changes from reverse to drive very quickly like it should.
But, it will not shift into second until I wind the engine way up and hit about 35 mph. I'm not sure of the exact speed it shifts from second to third, but it it is late as well. As I drive along, the shift point happens sooner and sooner until it seems sort-of almost normal and shifts at about 25 (still feels late). Even at it's best it doesn't feel right, and the shifts are sometimes accompanied by a surge forward.
Your help is much appreciated in advance!
Russ
Old Apr 3, 2012 | 11:00 AM
400 .040over's Avatar
400 .040over
sounds like time for a rebuild
Old Apr 3, 2012 | 11:04 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
That is a tough one where it changes as the truck in warmed up. I would start at the modulator that is the little canister at the back of the tranny with the vaccuum line hooked to it. Make sure you are getting good manifold vaccuum to that line then from there once you have good vaccuum it might pay to check the modulator itself for a bad spring, bound up rod, or a ruptured diaphragm. Look here first, This is usually what causes that real late 1-2 shift also check your kickdown rod for free operation and adjustment. If these don't improve anything then there might be an internal governor issue or a sticky valve body. Good luck.
Old Apr 3, 2012 | 01:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
X2 on vacuum modulator. Check the vacuum line going to it, make sure there are no cracks or kinks in the line. Pull the hose off where it connects to the modulator, see if any tranny fluid leaks out of the modulator. If it does, replace the modulator.
Old Apr 3, 2012 | 06:45 PM
fishthrower
Thanks everyone.
It has been pouring down rain today, but I crawled under there earlier and pulled the 10,000 year old vacuum hose off of there. No fluid came out at all, but I think I might be wise to replace the old, and likely cracked hoses, and see what happens.
Old Apr 3, 2012 | 08:02 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Also check the vacuum line at the back of the intake manifold. That hose that connects to the tube that supply's vac to the modulator can be cracked too. In other words there is a rubber hose at both ends.
TTsam
Aug 26, 2024 09:51 AM
lineman113
Dec 2, 2013 09:04 PM
parkerparkerm
28
Oct 14, 2012 11:39 PM
79FordBlake
13
Nov 9, 2011 05:47 PM
684rd
Mar 4, 2001 06:35 PM
