Inj. Control Press.
Old Apr 3, 2012 | 11:58 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
Ok ,I am going to look at what #s I have in the scan guage, gotta be a screw up on my input. You sure it wont go on 36 psi.lol
Good to see you back from lunch Benny.
Old Apr 7, 2012 | 01:18 AM
mhatlen's Avatar
mhatlen
Dyslexic Putz
Originally Posted by texastech_diesel
ICP of 36 and 50 can't be right, check to make sure your codes are put in correctly. The truck needs 500 just to fire the injectors, it should be around 580 or 620.
Okay both of you wer'e right I started getting rum dumbed with all the number inputs. Both IPR and ICP #s were screwed up in scan-guage.
Will get #s in morning, Thanks Mark......
Old Apr 7, 2012 | 09:46 PM
mhatlen's Avatar
mhatlen
Ok Blade I took time too get #s now that I have the coorect numbers in my scan guage.
This is what it says at the diff speeds you sent. Mark......
IPR#s
koeo= 14.4
idle = 21.4
1400=27.1
2000=29.5
2500=36.2
ICP#s
koeo=0
idle581
1400=837
2000=940
2500=1260
Old Apr 7, 2012 | 11:14 PM
BLADE35's Avatar
BLADE35
IPR#s
koeo= 14.4
idle = 21.4
1400=27.1
2000=29.5
2500=36.2
ICP#s
koeo=0
idle581
1400=837
2000=940
2500=1260
Those look good KOEO and Low iDEL and High Idel(2500rpm) close enough
What you want to look for is 500ICP minimum with say a no start
or Like a A High IPR% number the IPR% will get high if the system is trying to make up for a HPO Leak
I dont have any value for 1400 or 2000rpm Bryan Might he has some other info I dont have yet
Restlesswildman
Jul 18, 2015 03:15 AM
amdriven2liv
Aug 27, 2011 01:42 PM
BENG0924
May 24, 2008 10:30 PM
'86_150
Aug 26, 2007 11:38 PM
screw'd
1997 - 2003 F150
Aug 31, 2004 12:13 AM
