Sponsored by: Auxito
p0004 code?
Old Aug 30, 2004 | 10:04 PM
screw'd's Avatar
screw'd
p0004 code?
I now know the definition of this code but what does it mean and what would cause this. I've got the misfire bugs worked out but i'm left with this code and not at all sure what (fuel volume regulator circuit high) really means. my truck is an 02 s-crew 4.6L 70,000 miles. thanks Jay
Old Aug 30, 2004 | 11:54 PM
Racerguy's Avatar
Racerguy
Are you sure it's a P0004?
I've never seen that code.
Old Aug 31, 2004 | 12:04 AM
screw'd's Avatar
screw'd
p0004 is what keeps coming up,the definition i've got isfuel volume regulator circuit highbut iIdon't understand what this means or what might be causing it. It all started with a rough idle and a p0304 so i changed out #4 COP and fixed the rough idle but now I keep getting this dtc and am at a loss
Old Aug 31, 2004 | 12:09 AM
Racerguy's Avatar
Racerguy
Well according to the Ford shop manual a P0004 isn't a valid code. It doesn't show up in the code charts. These engines dont use a "fuel volume regulator", they use a fuel pressure regulator.
Do you have a chip or tuner?
Old Aug 31, 2004 | 12:13 AM
screw'd's Avatar
screw'd
yes hypertech tuner, but I get the same dtc with stock settings. I have no noticable problem but keep throwing this code
sandymane
20
Nov 13, 2016 07:41 PM
Deereguy90
Aug 20, 2011 09:28 AM
Donnie Reeves
Aerostar
Apr 14, 2010 06:36 PM
ford390gashog
Jun 30, 2004 02:18 AM
BigFord1977
General Automotive Discussion
Jan 30, 2004 09:20 PM
