I entered the code for inj.control press
07e0221446
046205140646
3010
003900640000
ICP
Now i need to know what the numbers should be
also is there a code for fuel press.
Thank You
What components does this test, fuel pumps ??
Will check again and @2500.
This Checks the Overall Health of the HPO System
Basicaly the FICM wont turn on the injectors till an ICP reading hits 500ICP PSI
ICP is most commonly Looked at for a NO STart (gotta have that 500psi) the ICP is a Pressure reader/how muchpsi you have
After that IPR% is looked at to Determine a HPO LEAK since the IPR is the pressure Controller
the IPR valve is Fulley Open at 0% (Creating a Lower ICP psi path to drain open) and Fulley Closed at 100% (Creating High ICP psi path to drain closed)
so that said 24% IPR is around what you want at Idel But lets say its NOT but reads 30% at Idel so at 30% the Valve is closed more (blocking HPO Pump Drain) trying to make up Oil Pressure for a Leak cuz ICP is reporting LOW PSI
Just let the treuck Idel on its own for Low Idel Number reading
and then take the numbers again at High Idel or 2500RPM
same as you did Before truck in park and ECT around 190* close is great
ICP of 36 and 50 can't be right, check to make sure your codes are put in correctly. The truck needs 500 just to fire the injectors, it should be around 580 or 620.
Hey guys sorry to butt in but I'm soooo confused about the ICP. I have the edge evolution which reads ICP voltage. Today when I was driving I got on it a bit, around 50-60% throttle and my egde is preset to alert at 4.0 volts. It started beeping of course. At idle it reads .9 volts and climbs as I increase throttle. I thought the ICP just read hpop for engine start. Can somebody please lay it out for me?? Thanks in advance
