Modular V10 (6.8l)
miss without setting code?
Old Apr 2, 2012 | 09:50 AM
jspringator's Avatar
jspringator
I'm at the shop right now. Engine misses like the chronic COP issue I've had many times. Mechanic claims no codes, pending or otherwise. I have a 5 star tune on it. Can this affect the code reading?
I'm on vacation and don't want to get ripped off.
Old Apr 2, 2012 | 11:04 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Sorry for your troubles while on vacation. That stinks.
The tunes should not "block" codes from registering. There are lots of threads about COP's going bad without setting codes even without tunes.
Keep in mind that it could be an injector, spark plug or just a boot.
Old Apr 2, 2012 | 11:59 AM
jspringator
I replaced all my COP's as preventive maintenance last year. New fuel pump last week. I don't want to throw parts at it without knowing what it is, or at least what cylinder is involved. I guess it will set a code eventually. I may have it scanned at the Ford dealer before I leave. Injectors are original with 165,000 miles.
Shop checked it out and couldn't find anything. Good guys; didn't charge me. Midas, Orange City Florida.
Old Apr 2, 2012 | 01:12 PM
mudfuel06's Avatar
mudfuel06
It could set a "soft" code, I don't think Midas would have the scanner to pick it up. Any shop that has a Snap-on scanner or something similar should be able to detect it. The shop that I use was able to tell me when I had to COP's going out even though the truck had just started acting funny.
Old Apr 2, 2012 | 01:26 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Nice of the Midas guys.
Dealership will charge a 1 hr labor rate. Call ahead to find one that has a decent price. 20 min away I have a stealership that charges $92 an/hr + 3% "shop supplies" (don't need shop supplies on a diagnostic) or I can go 30 min south of me and they only charge $70 an/hr +$2 for "shop supplies".
The other thing you might try is pulling one plug off of each COP "at a time" to see if you can hear the misfire change. This worked for me. The one that doesn't change the idle is your culprit. Then you need to figure out what part. Hope that helps.
Old Apr 2, 2012 | 04:03 PM
jspringator
He tried that and couldn't find the problem. He said they had a Snap On $8,000 tool that was 2 or 3 years old. There is a dealer a few miles from the campground I'm going to try before I leave.
Old Apr 2, 2012 | 05:51 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
If, by pulling the COP plug, didn't make a difference then that tells me that it is not spark related, right? So then I would lean toward a bad injector, injector plug or injector o-ring. Could it be fuel related, such as your fuel filter?
Old Apr 2, 2012 | 06:32 PM
jspringator
He checked fuel pressure . Over 40 lbs. A bad injector should set a code too. Of course, it idled perfectly when it was in the shop. It is worse when cold and in the rain. Failed COP symptoms to a T.
Old Apr 2, 2012 | 06:52 PM
jh818's Avatar
jh818
Could be worn boots. Water gets down in the spark plug. Maybe in the cold, the boots material shrinks and increases the crack in the rubber causing misfire?
Old Apr 2, 2012 | 07:14 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Sounds logical.
Old Apr 3, 2012 | 12:15 AM
PartsPaul62's Avatar
PartsPaul62
Banned
No codes
The V-10 is classified as a 'heavy duty engine' and the parameters for turning on the CEL are much different than a light duty truck or car.
I had a '01 that had a COP wiring issue and it never turned the light on. 125 miles on 9 cyls pulling a 10k fifth wheel.
Someone with more than a scan tool is required. Or just limp it home and tune it up next week...
P.S. I was working on my truck yesterday and noticed the emissions decal says the truck has an OBD II system, old school stuff.
It's amazing that it still runs clean enough to get an "ULEV" sticker (ultra low emissions vehicle)!
btsb032304
Sep 3, 2010 07:22 PM
greenego
May 14, 2010 07:57 PM
fixnair
Feb 15, 2010 11:23 PM
ford montana
15
May 9, 2009 08:46 PM
Antelope V-10
Modular V10 (6.8l)
Aug 5, 2008 04:46 PM
