code readers
Old May 8, 2009 | 06:54 PM
ford montana's Avatar
ford montana
Unhappy code readers
hey everyone, got my self a problem. ses came on yesterday, trucks running rough ,doesn't have enough power to get out of it's own way. 2000 cc dp tuner. It feels like an injector miss took it to a friend of mine with a code reader, but it says NO CODES. can anyone tell me if this reader will work for our trucks or do i need to take it somewhere else. code reader is INNOVA 3100. THANX FOR YOUR HELP
Old May 8, 2009 | 06:59 PM
leekingen's Avatar
leekingen
Sorry but no the one i use is a superchips 1705
Old May 8, 2009 | 07:04 PM
big poppa's Avatar
big poppa
From what I understand, certain code readers won't work, I use my Superchips tuner-code reader, I just pulled some codes recently. Sounds like the dreaded UVH harness again. I never had problems with mine but the experts will be by soon to verify, good luck..
Old May 8, 2009 | 07:14 PM
Pocket's Avatar
Pocket
No, that scanner is not compatible with Powerstrokes. That's why it won't pull codes.
Old May 8, 2009 | 07:26 PM
ford montana
Smile Thanx
thanx for your input Pocket i knew some one hear would be able to help ,thanx everyone .tomorrow i will have to find a good code reader,even if i have to go to the stealership
Old May 8, 2009 | 07:49 PM
mudmaker's Avatar
mudmaker
Where are you located?
Old May 8, 2009 | 07:52 PM
big poppa's Avatar
big poppa
If you want a top notch code reader, the AE Scan tool seems to be a very good one, tells you everything, and I mean everything. Somebody with one will let you know how much and where to get it..
Old May 8, 2009 | 08:00 PM
ford montana
flathead county columbia falls
Old May 8, 2009 | 08:04 PM
mudmaker's Avatar
mudmaker
Sorry, I am up in MT right now and have a superchip reader with me, but I am down in Hardin. About as far away and still in MT as possible! LOL.
Old May 8, 2009 | 08:30 PM
megawatt00's Avatar
megawatt00
I actually called the company to verify if it would work on a PDS and they said no.
Old May 8, 2009 | 08:57 PM
F350-6's Avatar
F350-6
Do you have a multi-meter than can read ohms? Maybe we can save you some money. Read this thread and see if it sounds like you're problem https://www.ford-trucks.com/forums/8...ck-shakes.html
Old May 9, 2009 | 06:12 PM
ford montana
Thumbs up You guys are awesome
Well once again the fine folks on this forum saved me a bunch of money . Your trouble shooting methods and thoughts of the problem were spot on. It did end up being UVH ,the ohm test showed nothing on the left side , pulled the valve cover off and it was just sitting there. Made the reconnect ohmed it again read right on the money. As i started to put it back together i retorqued everything , all was tight. Did the quarter mod(half the .50 mod), since i had the doghouse off i did the CCV mod(on the cheap,no collector yet) while i was already dirty i went ahead and did the foil delete. All of this was done with the great direction from you fine folks . With out you people i would have been at the mercy of the stealship and my wallet would be a whole lot lighter.THANX AGAIN HOPEFULLY I WILL BE AS SMART AS YOU GUYS SOME DAY. CRAIGhttp://images.ford-trucks.com/forums/images/smilies2/fte1.gif
Old May 9, 2009 | 07:43 PM
mudmaker's Avatar
mudmaker
Glad it worked out for you. Sounds like you made the most out your day!
Old May 9, 2009 | 08:09 PM
big poppa's Avatar
big poppa
Glad you got it, I wouldn't have known that without this site, happy motoring..
Old May 9, 2009 | 08:12 PM
F350-6's Avatar
F350-6
Glad to hear you got it all fixed up Craig. With the money you saved, maybe you should consider spending $20 and get a supporter badge next to your name.
