Sponsored by: Auxito
Brake issue
Old Apr 1, 2012 | 08:51 PM
shapechanger101's Avatar
shapechanger101
Brake issue
We have a 97 f150, with a 5.4 auto 2wd. The brakes were giving us problems, they would grab extremely hard and fling you forward. I took a look at them one day and the driver side pads were completely destroyed and there was a huge gouge in the rotor, the passenger side was ok though.
So both sides got new rotors and pads, repacked bearing and new grease seals.
Fast forward a week and an half, the driver side is starting to get grooves on the rotor, but the passenger side doesnt look like a pad has even touched it, or has been very lightly touched.
I have replaced the caliper on the driver side but it still appears to be fully extended at all times. I cant turn the tire or rotor with no pressure applied to the pedal, unlike the passenger where i can spin the tire with no pressure on the pedal.
Old Apr 1, 2012 | 10:18 PM
Nealcrenshaw's Avatar
Nealcrenshaw
Your brake hose has a restriction in it,its not releasing the pressure,replace it.
Old Apr 2, 2012 | 09:34 PM
steve(ill)'s Avatar
steve(ill)
or, the brake caliper is frozen in place. Remember the two bolts you took out of the caliper to hold it on ? THe bolts go thru two sliding tubes that allows the caliper to float. You need to pull the tubes out of the rubber boot, wire brush and put a little oil on them and reinstall. Things should slide in and out easy. Put the caliper back on the truck with the two bolts. Youl should be able to push/ pull on the caliper and have it slide in and out 1/4 inch as it straddles the loose disc.
Old Apr 3, 2012 | 06:12 PM
shapechanger101
Ill try that before i replace the hose.
goingape
2004 - 2008 F150
Nov 11, 2010 08:27 AM
tm0231009
15
Jun 18, 2008 06:26 AM
A_Fire_InsideR1
Sep 17, 2005 03:14 PM
77300i6
Sep 27, 2004 06:18 AM
