Sponsored by: Auxito
I caused airbag error.
Old Mar 20, 2012 | 02:03 PM
rolloman's Avatar
rolloman
Cool I caused airbag error.
I pulled out the airbag diode in the fuse box under the hood while the engine was running. Then engine quit. Put diode back in and the engine re-started but now a picture of person in seat with airbag inflated in front of them is flashing on the instrument cluster. 1998 Ford F150 V6. How can I get rid of this?
Old Mar 20, 2012 | 07:44 PM
critterf1's Avatar
critterf1
Try dis-connecting the battery for a while.
Old Mar 20, 2012 | 08:03 PM
rolloman's Avatar
rolloman
I tried that but only for about 4 minutes. I'll try longer and see. Thanks.
Old Mar 20, 2012 | 08:11 PM
projectSHO89's Avatar
projectSHO89
Count the flashes to determine the two-digit flash code. Then, SEARCH for previous threads about that error code by using the search string of "+LFC +XX" where XX= the fault code.
Disconnecting the battery is a waste of time. It won't make any difference.
Old Mar 21, 2012 | 07:42 PM
rolloman's Avatar
rolloman
The code is 52. What I found is that I need to turn the keyswitch on/off 256 times and let the self test run thru. Or else eventually it will dissapear after 256 starts and restarts under normal driving. I think I'll sit in the driveway and do as many as I can.
Old Mar 28, 2012 | 09:13 PM
rolloman's Avatar
rolloman
Started and stopped engine in driveway 256 times and I still have the airbag error 52. Any suggestions from folks who have had this error. I originallly got the error when I removed a diode in the fuse compartment under the hood. The engine quit and wouldn't run until I put it back in so I know I didn't hurt anything.
The error should have gone away if everyone is right about 256 starts.
Old Mar 29, 2012 | 06:26 AM
projectSHO89
The 256 number comes from the factory service manual.
Alternative is to find someone with a scan tool that reads SRS codes and have them reset the codes.
Old Mar 29, 2012 | 06:30 AM
rolloman's Avatar
rolloman
thanks, I'll try Autozone. Advance Auto won't do it anymore.
Old Mar 29, 2012 | 06:43 AM
projectSHO89
AutoZone can't do it. You'll need a shop or mechanic with a REAL scan tool.
Old Mar 29, 2012 | 08:17 PM
rolloman's Avatar
rolloman
Yeah, I found that out. They said they could read it but not reset it. When they read it their device didn't even show the airbag 52 error that I had. Instead it said something about a lean bank and he said it was probably a dirty O2 sensor. I bought some additive to try cleaning the O2 Sensor. As far as the airbag problem I kinda figured out what you say about a mechanic will have to reset it. That's my next plan is to find one that won't charge and arm and a leg. Ford dealer wanted a straight $80 to just hook up the tester. Thanks for the advice. I'll keep you posted.
Old Apr 3, 2012 | 06:35 PM
rolloman's Avatar
rolloman
If the battery is low while doing the 256 key cycles will it clear?
teamlx88
Nov 5, 2012 05:20 AM
Trucked
1997 - 2003 F150
Sep 22, 2011 08:04 PM
slickrock
1997 - 2003 F150
Dec 26, 2006 06:50 PM
sas
Aug 26, 2004 08:58 AM
powerpro
1997 - 2003 F150
Jan 26, 2004 11:46 PM
