what speedometer gear do i use???
Old Apr 3, 2012 | 11:41 PM
kedwinh's Avatar
kedwinh
That only leaves the drive gear inside the tranny. If you can spin the gear on the cable and the speedo works, and the cable is fully seated in the trans, everything else is eliminated. If yours is like mine, and it should be, it's almost impossible to see the drive gear with the tranny mounted. Could always pull the driveshaft and tail housing on the tranny and check it out. If you decide to do that just as well to put on the right drive gear.
Old Apr 5, 2012 | 12:49 PM
Daltonsheets1995's Avatar
Daltonsheets1995
Ok I got a flashlight and looked in th hole and I can see the gear. It's white. Its not tore up at all but it slides back and forth an I can spin it with my finger idk if it's supposed to do that
Old Apr 5, 2012 | 02:59 PM
kedwinh's Avatar
kedwinh
If you can spin it with your figure then it, or the tail shaft, are more than likely bad. The gear shouldn't spin freely on the shaft.
crucialprospect
16
Jan 3, 2018 05:04 PM
Zachthemoo2
Oct 2, 2014 04:42 PM
davewave649
Aug 27, 2012 12:14 PM
Rollbar
1997 - 2003 F150
Apr 5, 2011 11:48 AM
yellow72f100
Nov 2, 2005 06:52 PM
