i just put a 4 speed manual in my 82 and i cant find a speedo gear that works in it. i had a automatic and that gear dont work. can some one pleeease help me
ive got a 16 tooth in it right now and it does absolutly nothing. it came out of another standard tranny though. i left the one that was in the new tranny on the truck at the jy and when i went back for it the truck was crushed. i know my speedo works because i can turn the gear by hand and watch it go.
How do I find out exactly what tranny I got. All I know is it's a 3 speed with 4th as od. And it doesn't have the shift linkage on the side of the tranny
Being a 3+o/d trans you probably have the SROD like I do. The gear on top is the right gear. If the drive gear is for the "right" pitch then it should show damage on the driven gear. Did you use the clip to hold the gear on?
If it does nothing when you installed it either
1, you don't have it in all the way
2, it isn't on the end of the cable all the way
3, your drive gear inside the transmission is bad
4, the cable is bad.
5, the speedometer itself is bad
Easy way to check the last two is with a drill hooked to the end of the cable.
I know my speedometer is good i spun the gear. The clip was on, it's on the cable all the way or the clip wouldn't go on right, I'm not sure bout the gear on the inside. The speedometer gear goes in the tranny on the driverside on mine
