1978 - 1996 Big Bronco
bronco needs help
Old Apr 2, 2012 | 04:16 PM
greystreak92's Avatar
greystreak92
I hear you there. For some reason folks cannot get it through their heads that you either get two-digit OR three-digit Codes... NEVER both. The counting game takes some practice to be certain. The pauses are consistent from the ECM during the test. The problem with that is what people believe is a "second". Always two-seconds between digits and four seconds between separate Codes. So, operator error, yeah, I'll concur, they run rampant.
Old Apr 12, 2012 | 01:38 PM
bluegoose95401's Avatar
bluegoose95401
i think its time for a new trans what years are interchangeable with the 94 4eod im gonna try and hit the wrecking yard and see if i can find any thing good don't really have much of a choice at this point
Old Apr 12, 2012 | 01:43 PM
andym's Avatar
andym
So you gave up on pulling the codes?
Old Apr 12, 2012 | 01:48 PM
Edgethis's Avatar
Edgethis
Well any trans with a Ford small block bellhousing will bolt up to the motor. A C6 would be nice but you'd lose overdrive....
Old Apr 12, 2012 | 02:01 PM
bluegoose95401
im still working on that my cousin works in a shop so i can use there code reader but i have to wait till he has time. i want to try and track down a trans beforehand just in case also when i changed the tans filter the fluid was clean no flakes no shavings i added a qt of Lucas stop slip to it and that dint help
Old Apr 12, 2012 | 02:03 PM
andym's Avatar
andym
So you don't want to spend $30 for a code reader but you want to drop a few hundred on a spare trans just in case the one you have is bad?
Great idea
Old Apr 12, 2012 | 02:04 PM
bluegoose95401
will any of the small block 4eods fit and hook up to the wiring harness
Old Apr 12, 2012 | 02:05 PM
bluegoose95401
lol i wasn't gonna buy the trans its just nice to have one lined up and ready for purchase
Old Apr 12, 2012 | 02:53 PM
andym's Avatar
andym
Yes but you want one either from a '93 & up truck or one that was rebuilt using the upgraded parts made available after that date.
Obviously it needs to be a 4x4 version.
Old Apr 12, 2012 | 07:11 PM
bluegoose95401
ok thanks that's nice to know. just changed the ect iat changed the thermostat housing and added a mechanical temp gauge in doing this found the thermostat had popped open and stuck so i changed put a new one in and went back to factory temp it seems to be running alot better now hopefully that fixed the prob just hoping that it was a miss diagnosis and that it was not the trans but we will have to give it a few days to see for sure
abs777
Electrical Systems/Wiring
Nov 15, 2020 02:10 PM
chrismartinez0
May 21, 2010 09:53 PM
CruiserClass
Feb 1, 2008 09:08 PM
JJAC
Nov 20, 2003 08:28 PM
straight 6's
Sep 8, 2003 09:32 AM
