RV cam
Old Apr 3, 2012 | 10:16 AM
PA74F250's Avatar
PA74F250
I'm sure you don't lug yours much either. My father in law likes to drag it down pretty good.
Old Apr 3, 2012 | 10:40 AM
MIKES 68 F100's Avatar
MIKES 68 F100
true , i haul ars not stuff .lol
Old Apr 3, 2012 | 10:41 AM
MIKES 68 F100
here's a calculator if you know all your specs
Engine Compression Ratio (CR) Calculator
Old Apr 3, 2012 | 10:43 AM
PA74F250's Avatar
PA74F250
Haha yea me too. He doesn't haul anything just drives it easy.
Old Apr 3, 2012 | 10:48 AM
PA74F250's Avatar
PA74F250
Thanks. I know most of the things needed except things like head gasket thickness. I'll have to try it out. It was mentioned that it could be 9:1 with the pistons they gave me. If that is the case I think I could live with that.
Old Apr 3, 2012 | 11:29 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Those 390/410 pistons will sit down in the hole about .100 lower than the old ones. In a 410, they gave ~10.5:1 CR, but in a truck 390 it was much closer to 8:1 CR.
Swapping those 390/410 pistons for a set of 360 pistons should put it back into the low-mid 9's, and I'll bet they will even look like the old ones. Ask the guys at napa to compare your old pistons to 360 pistons, and you'll likely see a close resemblance.
I'm running a mid 9's CR 390 (360 pistons), with a factory GT/CJ cam, on regular. It does like the mid grade a bit better, but will run on the lower end stuff. Timing is the key here. This engine is backed by a C6, which does help to minimize the lugging that can be accomplished with a manual.
Old Apr 3, 2012 | 12:41 PM
baddad457's Avatar
baddad457
Originally Posted by baddad457
I came up with 9 to 1, give or take a few tenths of a point.
I made a mistake in my figurin. I missed the rod length by a full tenth. Rogue's 8 to 1 figure is correct. In any case, if that cam's specs are the same as those on the same grind in a 335 eeries motor, it'll still work fine as that 400 I ran one in had around an 8 to 1 comp ratio.
Old Apr 6, 2012 | 09:31 PM
PA74F250's Avatar
PA74F250
Well no need to worry about those low compression pistons. Napa did take them back and gave me a set of the HF395P which had the same compression height as the ones I took out. Tommorow I think I might be close enough to start putting some of it together.
Old Apr 7, 2012 | 09:05 PM
PA74F250's Avatar
PA74F250
Well after about 3 weeks of waiting for machine works and parts since I started this project it's soon done. I know it seems like its been a lot longer but really has moved along nicely for the amount of work that's been done.
jonezzzman
Jul 31, 2013 10:22 AM
tpdaniels
Mar 24, 2013 11:16 AM
74fordtruck
Jan 31, 2007 09:10 PM
Todds79
Apr 11, 2005 03:17 PM
824x4ride
Mar 30, 2004 04:40 PM
