Spindle suggestions
Old 03-31-2012, 12:17 PM
keyul's Avatar
keyul
keyul is offline
Spindle suggestions
Hey guys, some of you may remember a while back I replaced the wheel bearings, and wheel seal on the front right side of my truck, but could not get the spindle off to do the spindle bearing and seal. My truck also needed brakes and I finally got around to doing the brakes yesterday, but when I took off the front right hub, again it was filled with dirty water. I know the bearings and seal are new, so it must be coming from the spindle. My problem is that I still cannot get the spindle off of the truck! I've removed the six bolts, hit it with PB, the torch, slammed a chisel between the mounting surface with a 3lb hammer and still it will not move.
I have to figure out how to get it off of there so I can replace the bearing and seal! Anyone have some suggestions? Usually I have no trouble with rusty stuff but this one is giving me a heck of a time!
Keyul
Old 03-31-2012, 12:53 PM
81ChopTop's Avatar
81ChopTop
81ChopTop is offline
Double up the spindle nuts and use a slide hammer, it'll pop right off with a few blows.
I believe I mentioned this method last time. It's the only way I do it and it doesn't damage anything.
Old 03-31-2012, 03:09 PM
keyul's Avatar
keyul
keyul is offline
Thanks for the suggestion! I must not of caught it last time! I'll go rent the 5lb hammer from the store!
Old 03-31-2012, 05:07 PM
keyul's Avatar
keyul
keyul is offline
Went to the parts store, rented a 5lb slide hammer, the guy also brought out a 4X4 spindle puller adapter that threaded right onto the spindle! Amazing how easily it came off, check it out:
Old 03-31-2012, 05:18 PM
keyul's Avatar
keyul
keyul is offline
Old 03-31-2012, 06:40 PM
81ChopTop's Avatar
81ChopTop
Good to hear you got it off.
The 2 qty is one kit for each side.
Old 03-31-2012, 07:24 PM
keyul's Avatar
keyul
keyul is offline
Thanks! I definitely need to buy a slide hammer, they make so many things a lot easier. Spindle bearing kit should be in at the store tomorrow morning!
Old 03-31-2012, 09:38 PM
bruno2's Avatar
bruno2
bruno2 is offline
Slide hammers are great. You will be suprised at how many applications they have. The 8.8 rearends need one to remove the axle bearings. They are useful when pulling tranny pumps also.
ericconn
10-20-2013 10:56 AM
Harrier
02-05-2011 08:03 PM
cline9394
22
12-10-2009 08:17 AM
akparker1
02-12-2009 10:23 PM
CBFryman
1983 - 2012 Ranger & B-Series
08-16-2006 04:32 PM
Quick Reply: Spindle suggestions
