...... No Heat......
Old Apr 29, 2003 | 02:50 PM
kasparsport's Avatar
kasparsport
Question ...... No Heat......
Hi all... I changed the resistor, & the motor is good...but it still is not working...What else could be the problem??
Could it be the switch or just the wiring itself.?
Old May 1, 2003 | 08:06 PM
steve83's Avatar
steve83
Changing parts before you know what the problem is is a good way to waste money, but it rarely fixes it. Is the fuse blown? Do you have 12V at the motor? You need to do some more diagnosis.
Old May 1, 2003 | 11:22 PM
kasparsport
your right steve...but taking it to a service station & having them charge me 60$ for a diagnostic check, I thought Id gamble & go with a new 12$ resistor...I LOST....
Iwas thinking resistor because for the last 2 years the heater would only work on high, until recently nothing comes out.
Old May 2, 2003 | 10:22 PM
Ultramagdan's Avatar
Ultramagdan
I would suspect the switch unless your motor has a dead spot on it.
Old May 3, 2003 | 07:36 PM
steve83's Avatar
steve83
Gamble another $12 on a Haynes manual and you'll never have to pay a service station again. It tells how to diagnose (and repair) almost everything on the truck.
Not putting all the information in your first post slows everything down. Is there anything else you've done, checked, changed, or noticed that could pertain to your blower motor not working? Did you check the voltage at the motor connector or at the resistor? Here are the current (Amps) & voltage readings you should get at the motor connector with it plugged in and the engine running:
Switch ......................... A ......................... V
Low ........................... 6.0 ...................... 5.0
Medium Low .............. 8.0 ...................... 7.0
Medium High ............. 15.0 ..................... 10.0
High .......................... 25.0 ..................... 12.8
Magnetic Clutch ........ 4.57 ..................... 12.8
Old May 4, 2003 | 09:21 AM
kasparsport
Thanks for all the info. Steve.
reg1952
18
Dec 10, 2016 05:55 PM
Vsanzbajo
34
Apr 14, 2014 06:40 PM
PsD007.3
28
Apr 8, 2009 09:06 AM
taskdillon
Feb 4, 2008 07:59 PM
Kenny
16
Nov 29, 2001 10:18 PM
