Could this work?
Old Nov 26, 2016 | 07:00 PM
reg1952's Avatar
reg1952
Could this work?
I have some Mono brand acoustic sealer in a caulking gun tube. It is pretty much just butyl rubber. Could it be used to seal windshield?
Old Nov 26, 2016 | 09:18 PM
drptop70ss's Avatar
drptop70ss
Maybe, but the correct 3M stuff isnt much money to know for sure.
Old Nov 27, 2016 | 10:04 PM
Don T's Avatar
Don T
Hello reg1952, no and big no, acoustic sealant will flow when it gets hot and is awful to use, it is used for sealing poly vapor barriers as well as acoustic purposes.
Old Nov 28, 2016 | 06:45 PM
reg1952's Avatar
reg1952
What brand name should I ask for up here in Ontario. Everyone I ask thinks I have 2 heads. Someone have a part number I could give the parts store. Thanks
Old Nov 29, 2016 | 03:48 PM
CBeav's Avatar
CBeav
Swing by an auto glass shop or a paint and body supply house, either will know what's available in your area.
Old Nov 30, 2016 | 12:13 PM
petemcl's Avatar
petemcl
Use the right butyl material. Not worth the risk.
Old Nov 30, 2016 | 05:12 PM
reg1952's Avatar
reg1952
Is this the right stuff?(3M™ Auto Bedding and Glazing Compound, 08509)
Old Nov 30, 2016 | 09:34 PM
drptop70ss's Avatar
drptop70ss
Looks like the right stuff, I bought a tube of it but didnt use it, my seal fit pretty well so I am hoping for no leaks. If it leaks then I will add the sealer, looked like too messy of a job to try using it while installing the glass.
Old Dec 1, 2016 | 06:20 PM
reg1952's Avatar
reg1952
Originally Posted by EBEAR
Wow how is this so f%cked up go to a glass shop and ask for the right stuff , if you think saving $ 3 on a tube of sealant is worth the savings then by all means go for it
And I was always told there was never a stupid question. I went to a glass shop and they said they had not done a windshield like this in a long time and was pretty sure the 3m product was what I needed but where not sure so that's why I asked again. Sorry!!
Old Dec 1, 2016 | 07:00 PM
petemcl's Avatar
petemcl
It is good that you asked the question. I suspect that there are others that agree.
Old Dec 1, 2016 | 10:39 PM
Cougar54's Avatar
Cougar54
I agree, there are no stupid questions. Some people need some patience.
Old Dec 1, 2016 | 11:36 PM
EBEAR's Avatar
EBEAR
No I'm sorry no need to react like I did although I do find it odd that a glass shop wouldn't have or at least be able to order you the right stuff . Are you trying to fix leaks in a rubber gasket windshield or just wanting to put extra in when you install it ? If the rubber is in good shape it's rare that it would need sealer
Old Dec 5, 2016 | 07:12 PM
Don T's Avatar
Don T
I am also in Canada like reg1952, carpenter suggests using a specific sealant (which I cannot even find on the internet) the glass shop suggested a butyl sealant (which they cannot get any more) but sent me to a body shop supply (older guy there also said they could not get it any more and suggested to try it dry) the auto glass shop also thought I had 2 heads (young guy) and said they only use urethane, told him I was looking for a sealant not a glue? I was going to try "lumber yard butyl" but decided it looked too thick or heavy. The point is this is still a legitimate question.
Old Dec 5, 2016 | 07:28 PM
petemcl's Avatar
petemcl
I think what you proposed in post #7 is OK. Suggest that you call 3M or Eastwood.
Old Dec 5, 2016 | 09:30 PM
EBEAR's Avatar
EBEAR
There are also a number of seam sealers that stay pliable if you are trying to fix a small leak
