1978 - 1996 Big Bronco
switch to manual?
Old May 2, 2003 | 12:02 AM
BroncoRoadKill's Avatar
BroncoRoadKill
switch to manual?
Personally, I've never seen a three screw manuels. Of coarse, I havent played with many 4x4s after about 87.
Old May 2, 2003 | 09:03 AM
mrwizard's Avatar
mrwizard
switch to manual?
Here's a picture of the three screw manuals.
Old May 3, 2003 | 05:23 PM
steve83's Avatar
steve83
switch to manual?
I just found a pair of 3-screw locks on an F-250 that was ready to be crushed, but I snagged 'em. If I ever swap a D50IFS in, I'll have some good OE locks.
Old May 4, 2003 | 01:47 AM
BroncoRoadKill
switch to manual?
Well, I'll be. I'll have to keep my eyes peeled for some of those.
Did'nt even know three bold manuels existed.
Thats cool.
Old May 4, 2003 | 06:38 AM
Sudsrat's Avatar
Sudsrat
Cool switch to manual?
Thanks for all the info guys, on this topic. I'm definitly going to make the switch to manuals(probably Warn). I drive the beaches
alot fishing,on the Northeast coast and the nearest help is usually
miles away, with a hefty charge for towing off the beach.
Sudsrat
Old May 5, 2003 | 09:39 PM
Dave Perry's Avatar
Dave Perry
Question switch to manual?
Steve83, Great pics... That should help. After removing the old hub locks on a '93 Bronco (with the 5 screws in the chrome cap)
the directions say to verify that the spindle nuts are installed and torqued to manufacture's specs. Do they mean the outer locking nut (torqued to 160-205 ft-lbs.), or should I go back to the bearing adjusting nut ( torqued to 50 ft-lbs.) first, then work my way out. These are the terms used by Chilton's manual.
Also, what is the size of the hub socket or the spanner socket (I think that's what you called it).
Sorry, but the directions and the manual don't seem together with their terms or diagrams.
I also want to verify that with the 5 screws in the cap setup you don't need to convert the spindle nut. Every catalog I look at lumps almost all Broncos together as needing a conversion kit (for around $40 extra).
Thanks again for the great pics and any help.
mj_355
Feb 28, 2013 04:40 AM
Glxy66
May 3, 2012 12:09 PM
orve
Oct 17, 2011 09:01 PM
mabc926
Sep 1, 2010 02:47 PM
walquist1
May 18, 2009 12:51 PM
