How to install Flywheel ring gear?
Old Mar 30, 2012 | 04:10 PM
asidpara's Avatar
asidpara
I ordered one for my 67, 5.8l. manual. In the picture, I did not see any mounting holes. Can some one help?
Old Mar 30, 2012 | 04:27 PM
Freightrain's Avatar
Freightrain
You'll need a torch, or at least one of those small propane torches.
Heat up a spot(not more then 1/4 of the diameter) and it will fall off. Have the wheel face sitting on a small block so that the ring can fall off.
Repeat the procedure to install. Use a pair of thick gloves, warm the ring up and then slip it down on against the shoulder on the flywheel.
Let cool. Presto, you're done.
If you don't want to do it yourself, find a automotive machine shop and they'll likely be glad to do it for you.
Old Mar 30, 2012 | 06:10 PM
asidpara's Avatar
asidpara
Installing Flywheel Ring Gear
I very much appreciate your solution. I do have a small propane torch and will definitely try to do it myself. I did not find this approach in the shop manual. Thanks a lot!
Old Mar 30, 2012 | 10:06 PM
Ford_Six's Avatar
Ford_Six
The last one I changed, I put the flywheel crank-side down on a block, and used a hammer and drift to drive it off, working around the whole thing a little at a time, keeping it even coming off there.
I put the flywheel in the freezer, and laid the ring gear in the sun. After a couple hours, the ring gear just dropped right on.
Old Mar 31, 2012 | 07:39 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Same principal. Take the ring gear to the kitchen and place on a pizza pan in oven telling wife you're cooking a pizza.
Old Mar 31, 2012 | 11:35 AM
BlueovalFE's Avatar
BlueovalFE
Dirt Bikes
Use to do the same thing when putting a new sleeve in a cylinder for my old dirt bikes. Put the new cylinder sleeve in the freezer, bake the cylinder at 350* for 20 minutes and slide it in. Kind of tricky getting the ports to line up in not much time but it always worked.
Old Mar 31, 2012 | 03:53 PM
asidpara's Avatar
asidpara
Flywheel Ring Gear
Mr. Super Moderator,
I mtried your recommendation. Used a punch and hammered ir around at equal, distance. In two rounds, it came off. I will have to wait u ntil I get the new gear and then do the instrallation. I was just too nervous until I used your method. I truly appreciate. I am a fairly new menber and so far it has always been my positive experience when ever I ran into any problem. I am proud to be a member of this group.
Thanks again! If you happened to be in Kennewick,WA statepl. see me and we will add some beer in out blood stream!
Old Apr 1, 2012 | 04:55 PM
highntight's Avatar
highntight
i personaly would use the oven or a magnet heater... worse case senairo a torch. but i would heat it evenly around the intire thing and i would definatly not heat one spot cherry red... it would only take a small amount of heat to get the few thousands fit your going for. but heating the new one in one spot might affect the material in that perticular spot. probably would never affect it... but if it did it would be that spot that you changed the integrity of the steal thats gonna fail... just my thoughts.
Old Apr 8, 2012 | 05:24 PM
asidpara's Avatar
asidpara
Thanks ro all the friends giving some ideas on installing the ring gear. I did removed it by using a drift all around . It came off without any problem. This was suggetsde by one member. I heat it in the kitchen oven at 480 degrees F and installed it. There was still about 1/16 th gap. I took it in the garage and used a piece of coppr rod and hammered it all arount while it waws still hot. It fitted quite well. It is very hard to tell tell what temp is the right one. I nshould have heated uit at higher temp. But once it waws on, there was no problem in fitting it right to the bottom.
I thank every one for taking interest in my issue and giving me very meaningful advice- promptly!
Ami Sidpara
Kennewick, WA
Old Nov 25, 2014 | 03:25 PM
69issofine's Avatar
69issofine
i grew up in kennewick well actually in finley but i have reletives all over down there campbells,prats batmens dickensons,theils,wow small world my wife has never been to the tri-cities before and the last time i was down there clearwater ave was 50 mph not 35 ask me how i found out, what are those pretty red and blue lights dad.
Old Nov 29, 2014 | 01:56 PM
willowbilly3's Avatar
willowbilly3
I've done dozens of them with a torch. I don't mess around getting the old one off, just cut through it with the torch. One thing nobody mentioned, all the Ford ones I ever did have a little taper to the gears and need to be installed the right way or the started drive won't release. I found that out the hard way.
5150 fear
13
Jun 10, 2014 10:21 PM
lifted79ford
Mar 26, 2008 11:30 PM
1982fordf100
Jun 17, 2006 02:02 PM
SawZall
Sep 7, 2003 12:40 PM
chickenmanq
Jul 23, 2002 10:31 AM
