New
Old Apr 3, 2012 | 05:31 PM
Jstaabs64's Avatar
Jstaabs64
I finally figured out why it was pulling to the right the rear brakes had everything takin out of then and the adjuster on the left front the adjuster is not working
Old Apr 4, 2012 | 12:49 AM
Jstaabs64's Avatar
Jstaabs64
And I ordered my shifter stuff today form lmc and dennis carpenter way excited to have this thing running correctly now I just have to figure out the steering box. When I adjust it do I adjust it in or out. I figured in because that makes since to me but tell me If I'm wrong
Old Apr 4, 2012 | 01:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jstaabs64
Does anyone know the size of the o ring on the 292 oil pump cover plate with the 4 bolts on it?
B6Q-6619-A .. Gasket-Oil Pump Cover Plate / 2.93"/2.96" O.D. // .052"/.072" width // .065"/.085" thickness.
Applications: 1956/63 Passenger Car 256/272/292/312 & 1956/64 272/292 truck all with rotor type oil pump.
Old Apr 4, 2012 | 01:41 AM
Jstaabs64's Avatar
Jstaabs64
Thank you for the info but a day late I ordered a new oil pump due to the fact there were to broken bolts on the plate And me being the smart guy I am drill the wrong direction haha but I should be here tomorrow and running like a champ after I changes and gapped the plugs to .30 fixed all the exhaust leaks and fixing the brakes.
Old Apr 4, 2012 | 09:43 PM
Jstaabs64's Avatar
Jstaabs64
Does anyone know what year they switched to metric rims
Old Apr 5, 2012 | 12:15 AM
NumberDummy
F150 = 1997. No F100's after 1983, no Bronco's after 1996.
Old Apr 5, 2012 | 12:17 AM
Jstaabs64's Avatar
Jstaabs64
So anything 97 and below that has a 5 lug and comes off a ford will work?
Jstaabs64's Avatar
Jstaabs64
Sorry any f150 and bronco will work
Old Apr 5, 2012 | 02:15 PM
Jstaabs64's Avatar
Jstaabs64
Might have found some ranger f100 rims that the guy will trade me straight across
Old Apr 6, 2012 | 01:49 AM
NumberDummy
No such thing as "Ranger" F100 rims.
5 lug wheels on a 5.50" bolt circle:
1948/52 F1, 1953/79 F100 / 1966/96 Bronco / 1975/96 F150 / 1975/2012 E150 (no metric wheels for Econolines) / Some 1980/83 F100's.
Some 1980/83 F100's have 5 lug wheels on a 4.50" bolt circle.
Styled steel and aluminum wheels introduced 1977 for F100/150's and E150's. Bronco's got 'em in 1978. These wheels and variations thereof were used thru 1996. All are 5 lug, 5.50" except some used on 1980/83 F100's.
2WD wheels same as 4WD wheels.
If swapping in discs, you'll need wheels from 1973 thru 1996.
Old Apr 6, 2012 | 10:26 AM
Jstaabs64's Avatar
Jstaabs64
The badge on the driver fender said ranger then f100
Old Apr 7, 2012 | 06:09 PM
SuperSabre's Avatar
SuperSabre
I think what ND means is that these wheels are not specifically for the Ranger only. In '65 and '66 "Ranger" was an upscale trim package for the F100 and F250, not a stand alone model.
Old Apr 8, 2012 | 02:08 AM
  #28
NumberDummy
1965/69 F100 Ranger's used the same wheels as non Ranger's: Standard and Custom Cabs.
1970/72 F100 Rangers used the same wheels as Customs, Sport Custom's, Ranger XLT's.
1973 Rangers....
Bottom line: F100 Rangers used the same wheels as everything else. 1975/79 F100's used the same wheels as F150's.
And, these same wheels were also used on Bronco's.
Taylor Doyle
Feb 15, 2017 11:58 AM
learpilot
Nov 13, 2008 03:01 PM
Duke78
Oct 28, 2008 09:42 PM
gangstakr
Jun 25, 2006 09:30 AM
