intake questions.
Old Mar 29, 2012 | 02:36 PM
bigrig123's Avatar
bigrig123
intake questions.
hey guys will a 84-85 2.8 carb intake fit on a 86 2.9 engine? i really HATE FUEL INJECTION. but i dnt want to spend a arm and a leg switching it over if i dnt have to.
Old Mar 30, 2012 | 12:24 AM
KhanTyranitar's Avatar
KhanTyranitar
If you hate FI, you woke up in the wrong century? Can any carbed vehicle run 100,000 miles without maintenance on the carb or some kind of adjustments? Stick with FI, it needs no adjustment and just plain works, thats why carbs were abandoned.
The answer is probably no. Ford often deliberately made certain carb and EFI manifold so that they won't interchange unless you make modifications. With mods it might be possible, I'm not familiar enough with the differences between those two engines.
But honestly, what do you hope to achieve, converting to carb will likely be expensive, and will probably result in less power and worse fuel economy unless you are very experienced with adjusting carbs.
Old Mar 30, 2012 | 03:11 PM
bigrig123's Avatar
bigrig123
i got a f-100 with a 300 4 speed 2 barrel never been worked on i'm the 2nd owner and bought it with 49,xxx miles and its got 268,xxx miles now and i ain't done nothing to it i guess its jus luck of the draw and i was raised with carbs only and i'm not planning on putting a fortune in this truck and all its goin to be used for is a woods buggy. but it wont start at ALL so i dnt know wat to do except make it carbed so i can get it to run lol.
Old Mar 30, 2012 | 09:46 PM
Old93junk's Avatar
Old93junk
No, it will not..........If you are running the 2.9 you must stay with EFI.
I hate EFI as well, but sometimes it's the only choice.
Old Mar 31, 2012 | 12:46 AM
Lead Head's Avatar
Lead Head
The only people that hate EFI are the ones that don't understand it. Ford EEC-IV Fuel Injection is so simple that the only reason why you don't understand it is that you are too lazy and stubborn to learn it.
EFI is dirt simple. Start with the fuses and fusible links. Then move onto the real diagnostics.
An engine needs 3 basic components to run, whether it has carb or fuel injection:
Compression
Fuel
Spark
Does it have spark? No? Check for power at the coil - just like a carb vehicle. Then move to the distributor..
If it has spark, move onto fuel. Spray some starting fluid into the intake. Does it start up? If yes, check for fuel pressure at the rail. You can rent a fuel pressure tester from autozone (should be around 39 PSI), or just poke the schraeder valve with something and see if fuel sprays out.
If it doesn't start up on starting fluid, and has spark, move on to the engine itself. Are the plug wires on correctly? Are the sparkplugs fouled/broken? If the plugs and wires are good, then go onto check compression. Is it extremely low?
Those are just some basic troubleshooting tricks that ANYONE who works on cars should know, even if they've never seen fuel injection in their life.
It's not rocket science, and if you used the time you spent complaining about how much you hate fuel injection to actually look up how it works, you'd probably stop hating it so much.
Old Mar 31, 2012 | 01:03 AM
bankshot's Avatar
bankshot
Compression
Fuel
Spark
Wow. Just because you are right doesn't give you a license to be a dick.
jaye
Feb 18, 2009 07:41 AM
flatdeck 82
Sep 26, 2008 01:09 AM
ford_guy_08
32
Dec 20, 2006 12:00 PM
sideways4m
Mar 12, 2006 12:19 PM
