EFI to carb
Old Feb 16, 2009 | 05:15 AM
jaye's Avatar
jaye
EFI to carb
Could I take an Explorer 4.6 CID and put a regular intake & carb on it? I just don't know anything about wiring the computer & such for the EFI engine. I've seen lots of pics and you guys make it look & sound pretty simple.
Old Feb 16, 2009 | 09:26 AM
LEckart's Avatar
LEckart
Jaye, I've done that with a SBC engine but I'm not very familiar with doing it on a Ford engine. It seems to me if you could find an intake manifold you could do it. You might want to do some research and see if the cam needs to be changed to run a carb. Other than that it would just be linkage and fuel line to deal with. Any particular reason you don't want to run the EFI?
Old Feb 16, 2009 | 09:55 AM
CharlieLed's Avatar
CharlieLed
The earlier engines were all carb-based and then converted to EFI...this made it simpler to convert back to carb. I believe that the 4.6 is a modular motor and has no provision for a distributor and never had a carb manifold manufactured for it. You would be better off learning about EFI and enjoying the fruits of that labor in improved performance and reliability.
Old Feb 16, 2009 | 08:52 PM
tacson's Avatar
tacson
I agree with CharlieLed EFI is a good thing but if you must run a carb check this place out. Might be able to help you.
Ford 4.6L DOHC single plane intake manifolds
Old Feb 16, 2009 | 09:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Eveerything I have heard is that carb'd 4.6's are dogs. EFI is able to exploit their potential.
Old Feb 17, 2009 | 10:49 AM
jaye's Avatar
jaye
I don't have the 4.6 yet I drove my 55 with a 302 to work a couple times last week and noticed oil all over the tranny I looked and couldn't see where it's coming from it could be the engine I have to get it up on a lift to be sure since I lowered it I can't get under it. The engine was rebuilt in 1994 but it doesn't the mileage of a daily drive.
Old Feb 17, 2009 | 09:49 PM
mytbtruck's Avatar
mytbtruck
I have a 4.6 SOHC in my 48 truck. I did some research about manifolds and did find that they were available. I don't remember where because I gave up and went to the original setup. I think your biggest problem would be ignition. You would still need a harness and ECM to operate that part. I used the original ECM and ordered a wire harness to operate the engine and transmission.
Old Feb 18, 2009 | 07:41 AM
merc546's Avatar
merc546
Jaye, look at the rear of the intake manifold for your oil leak. Rear intake manifold seal may be your problem.
75Three90
Mar 19, 2020 04:51 PM
rentakid94
Nov 28, 2012 11:31 AM
lariat87
Oct 21, 2007 03:21 PM
phantom rider
Offroad & 4x4
Feb 2, 2007 07:32 AM
jrongi1
Dec 13, 2003 10:08 PM
