Suggestions for my dash?
Old Mar 31, 2012 | 04:16 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yea ya gotta be careful thats why there are not so many pick and pulls due to insurance reasons......but good score.
Old Mar 31, 2012 | 09:53 PM
johnson2007's Avatar
johnson2007
I have the intermittent wipers in my 79 from the factory, but the intermittent is VERY slow. There is no happy medium between the fast intermittent and the low speed (turned one notch to the right). Will the switch from a newer pickup have a few more intermittent speeds to choose from?
Old Mar 31, 2012 | 11:26 PM
PRIMERED79 SHORT BED's Avatar
Mine is the same way, i was wondering if it was time for a new setup.
Old Apr 1, 2012 | 02:24 AM
USArmyTaterness's Avatar
USArmyTaterness
I don't screw with electrical so by no means am I an expert but if you can find one that is close enough in design the only problem should be on how to wire it up and place it in the dash.
Old Apr 1, 2012 | 11:22 AM
GOVTMOD's Avatar
GOVTMOD
It occurred to me to check some other sources, there was supposedly a Lincoln and a T-bird on the lot but I didn't have time to check them out.
Old Apr 4, 2012 | 10:46 AM
GOVTMOD's Avatar
GOVTMOD
I got the replacement instrument cluster rebuilt with the 100 mph speedo. I had to repaint the speedo numbers and I painted all the gauge needles red, the speedo needle looked like it was a red that had faded to a dark orange and the gauges looked like they were an orange that had faded to a yellow. I changed out all the lamps for good measure, just standard 194LLs, I figured most of them had survived more than 30 years so the new ones should do the same. Besides, the shop I went to only had one pair of LEDs and the price was double the 194s. I'll have it back in in the next day or 2.
Old Apr 6, 2012 | 07:18 AM
GOVTMOD's Avatar
GOVTMOD
What about a tach? I see a lot of pics on here of a tach either added to the left on non A/C trucks above the light and wiper switches or strapped to the steering column. Is it something I should think about? I just intend this truck to be a driver and a light duty hauler, no mudding, crawling or hard core wheeling.
Old Apr 6, 2012 | 07:29 AM
77&79F250's Avatar
77&79F250
What do you really need a tach for, can you not just hear how the rpm's are doing and know when to shift? Turn the damn radio down.....lol
I mean no offence to those that have them, need them, or use them. They have there place in a truck, and there all kinds of reasons to have them bla bla bla, just shift ok?
I am just saying do not put one in to be "cool", besides putting it in a place where you have to take your eyes off the road to see what your rpms are, is not a good idea to me.
Notice why drag racers put them in front of the steering wheel and add a big shift light, they are a little pressed for time to hit the next shift.
Old Apr 6, 2012 | 08:40 AM
GOVTMOD's Avatar
GOVTMOD
Pretty much what I was thinking. I'm used to one now in my econobox. I didn't have one in my '86 Ram years ago and it seems like I ran fine. I was just wondering if there might be a solid reason to have one like making sure you keep your revs down to an absolute min for fuel econ..... I hear gas has hit over $5/gal in Chicago, coming soon to a pump near you.
Old Apr 6, 2012 | 09:38 AM
77&79F250's Avatar
77&79F250
And then you end up "lugging or bogging" it around and is that really any better a situation? Great that means diesel is over 5.50 probably....
Old Apr 12, 2012 | 11:22 AM
GOVTMOD's Avatar
GOVTMOD
Ok, I got the "new" cluster in. The lights work fine BUT when I turn the key to the run position the fuel gauge doesn't move. Can't turn the truck over since the carb is still sitting on the bench and I didn't want to pump fuel all over the engine. I know the truck has about a half tank and the gauge from the old cluster indicated such... I guess this means I'm going to have to pull it back out and swap gauges between the clusters. I'm guessing the other clusters wont indicate anything until the engine is actually running.
Old Apr 12, 2012 | 11:51 AM
OldStyle's Avatar
OldStyle
Rusty Roller
The fuel gauge would indicate with just the key on. However there were a few different dash circuit boards. There is a Ford number on the board and it needs to be the same as your original. The gauge may be bad but if the number is different you will need to transfer your board to the new dash. The voltage regulator on the board might be bad too.
Old Apr 12, 2012 | 08:56 PM
  #28
GOVTMOD's Avatar
GOVTMOD
You rock! Good news: it works, Bad news: I only have a 1/4 tank of gas.
I pulled the cluster back out and the circuit boards matched. So I pulled the voltage regulator off the "old" cluster and swapped it on to the "new" one. Plugged it back into the harness then turned the key to "on" and the gauge came up.
Note: the regulator must have a capacitor in it as it takes 5-10 seconds for the lights and gauges to start to work after turning the key to on.
Mr7.50headsup
Nov 15, 2013 05:01 PM
Gregory Glaser
Aug 18, 2007 03:08 PM
Thomsen
Offroad & 4x4
May 4, 2005 09:31 PM
77Lance
Jul 15, 2004 03:10 PM
don_79f250
General Automotive Discussion
Jul 7, 2004 05:52 PM
